Ir para o conteúdo principal
How to Fix A Broken Makeup Compact Without Alcohol
Cura Mclemore
Cura Mclemore e um outro colaborador
Última atualização em May 24, 2023
25 minutos
Moderado
Introdução
Ir para o passo 1
Use this guide to fix your favorite makeup compact. After a compact is dropped on the floor or has gotten old and cracked, this guide can help restore it. With a hot iron and kitchen silverware, you can press your powder back into place in no time.
Before using this guide make sure you're working on a clear surface, free of clutter and safe for the placement of a hot iron. Keep your hands steady while you're using the knife to remove the metal pan from the compact in step 4. Make sure the iron is unplugged and completely cooled before storage.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. How to Fix A Broken Makeup Compact Without Alcohol, How to Fix A Broken Makeup Compact Without Alcohol: passo 1, imagem 1 %32
    • Plug In the iron and turn the heat to the highest setting.
    • Caution: Be sure to place the iron on a flat, solid surface, away from plastic and other flammable objects.
  2. How to Fix A Broken Makeup Compact Without Alcohol: passo 2, imagem 1 %32
    • Pour the broken powder into a plastic sandwich bag.
  3. How to Fix A Broken Makeup Compact Without Alcohol: passo 3, imagem 1 %32
    • Use a spoon to break the powder down into a fine dust.
  4. How to Fix A Broken Makeup Compact Without Alcohol: passo 4, imagem 1 %32 How to Fix A Broken Makeup Compact Without Alcohol: passo 4, imagem 2 %32
    • Take a knife and carefully remove the metal pan from the compact.
  5. How to Fix A Broken Makeup Compact Without Alcohol: passo 5, imagem 1 %32 How to Fix A Broken Makeup Compact Without Alcohol: passo 5, imagem 2 %32 How to Fix A Broken Makeup Compact Without Alcohol: passo 5, imagem 3 %32
    • Pour the powder into the metal pan and begin to press the powder down with the spoon.
  6. How to Fix A Broken Makeup Compact Without Alcohol: passo 6, imagem 1 %32 How to Fix A Broken Makeup Compact Without Alcohol: passo 6, imagem 2 %32 How to Fix A Broken Makeup Compact Without Alcohol: passo 6, imagem 3 %32
    • Turn the heat off on the iron.
    • Caution: Be sure to unplug the iron.
    • Use the heat from the iron to secure the powder in the pan.
    • Press down for 15 seconds at a time.
    • Repeat as needed.
  7. How to Fix A Broken Makeup Compact Without Alcohol: passo 7, imagem 1 %32 How to Fix A Broken Makeup Compact Without Alcohol: passo 7, imagem 2 %32 How to Fix A Broken Makeup Compact Without Alcohol: passo 7, imagem 3 %32
    • Let cool completely.
    • Place metal pan back into the compact.
    • Now the compact is ready for use.
Linha de Chegada
Cura Mclemore
Membro desde: 03/21/23
145 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 268
