Ir para o conteúdo principal
How to Fast Fix a Crack on Granite Countertop
Deborah Kalu
Deborah Kalu e 2 outros colaboradores
Última atualização em August 23, 2023
45 minutos - 1 hora
Fácil
Introdução
Ir para o passo 1
Some people overlook cracks on their countertops because it's expensive to replace and/or hire a specialist to fix the damage. Cracks can grow over time; therefore, it is crucial to stop the progression of a crack as it can damage the stone, costing the owner extra money to repair or replace.
A good repair option for a crack is to fill it in with a material that bonds with the granite or stone, which will prevent further expansion and promote the durability of the countertop, saving the owner money and also saving our environment the impact caused by extraction of rocks to manufacture granite countertops.
This quick and easy guide will show you how to fix or repair cracks and chips on granite countertop.
  1. How to Fast Fix a Crack on Granite Countertop, How to Fast Fix a Crack on Granite Countertop: passo 1, imagem 1 %32
    • Ensure the surface to be cured is clean and dry.
    • When epoxies are mixed, the compound hardens rapidly. Before mixing, it is crucial to prepare the surface for repairs and to mix just enough to get the job done.
  2. How to Fast Fix a Crack on Granite Countertop: passo 2, imagem 1 %32 How to Fast Fix a Crack on Granite Countertop: passo 2, imagem 2 %32 How to Fast Fix a Crack on Granite Countertop: passo 2, imagem 3 %32
    • Measure and mix an equal proportion of hardener and resin.
    • For a good curing effect, epoxy resin and hardener should be measured out in a 1:1 ratio.
    • Epoxy resins are safe to use if managed appropriately. Do not swallow; may be poisonous if swallowed.
  3. How to Fast Fix a Crack on Granite Countertop: passo 3, imagem 1 %32 How to Fast Fix a Crack on Granite Countertop: passo 3, imagem 2 %32 How to Fast Fix a Crack on Granite Countertop: passo 3, imagem 3 %32
    • Add a small amount of tint to the hardener and resin.
    • Stir in until thoroughly mixed.
    • Tinting is optional when sealing or rejoining a piece of granite that has a clean split with no missing fragments.
    • Do not add too much tint!
  4. How to Fast Fix a Crack on Granite Countertop: passo 4, imagem 1 %32 How to Fast Fix a Crack on Granite Countertop: passo 4, imagem 2 %32 How to Fast Fix a Crack on Granite Countertop: passo 4, imagem 3 %32
    • Apply the mixture to the crack or damaged area.
  5. How to Fast Fix a Crack on Granite Countertop: passo 5, imagem 1 %32 How to Fast Fix a Crack on Granite Countertop: passo 5, imagem 2 %32
    • Tape the cured area with some painters tape.
    • It is optional to use the painters tape on a flat surface. The strip aids in molding the epoxy to precise curves.
    • Allow to dry for 30-45 minutes.
    • Before removing strip, lift and feel the epoxy, and ensure it is dry.
    • Once dried, slowly peel back the tape and shave off the dried excess with a putty knife.
  6. How to Fast Fix a Crack on Granite Countertop: passo 6, imagem 1 %32 How to Fast Fix a Crack on Granite Countertop: passo 6, imagem 2 %32 How to Fast Fix a Crack on Granite Countertop: passo 6, imagem 3 %32
    • Use a putty knife or a razor to scrape off excess epoxy.
    • For a visibly flat finish, it's best to use a razor to scrape off the dry epoxy.
  7. How to Fast Fix a Crack on Granite Countertop: passo 7, imagem 1 %32 How to Fast Fix a Crack on Granite Countertop: passo 7, imagem 2 %32
    • Depending on the product used, The finished surface may look glossy.
    • Apply a granite sealer over the area.
Conclusão
Enjoy your crack free countertop!
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 17
Últimos 30 dias: 72
Ao todo: 2,632
