Ir para o conteúdo principal
How to Diagnose an Engine Problem
Taylor Whitney
Taylor Whitney e um outro colaborador
Última atualização em 7 de jun de 2019
Nenhuma estimativa
Moderado
Introdução
How to diagnose an engine problem.
O que você precisa
Ferramentas
Instruções em vídeo
Linha de Chegada
8 outras pessoas executaram este guia.
Gear Up For Future Repairs
Shop all
Taylor Whitney
Membro desde: 11/06/15
11.111 Reputação
Autoria de 13 guias
6Comentários do guia
Question,, I have a 1999. Ford F150 4x4 5.4 engine. Was making a clanking noise last night I was going down road and it shut off. I thought it jumped timing, but this dude told me to check the torque converter. Could this be true, or the bad news that it is my engine. Please help. Thank You. Reply to: Sahutto122666@gmail.cim
Sherry Annette Horton Hutto - Responder
Feeling desparate can torque converter cause problems associated with the engine?
I doubt that it's a torque converter, without hearing it I'd have no idea what's going on , Id have a repatable technician take a look at it
Tim -
Bought an old Suzuki Ute Trayback to use around the farm. Previous owner’ s children drove it 5 km morning and afternoon to catch school bus. It has some mods like an electric fuel pump on an extra large fuel tank probably part of the conversion to a trayback.
it starts ok, lots of choke, will idle for twenty minutes, no probs, but when I drive it around it starts to run rough after ten minutes or so. Gradually it loses power, seems to be running on three cylinders then stops and won't restart until it cools right down about half an hour later. No sign of overheating on gauge, has oil and water.
would you suggest fuel or ignition probs?
Brian Ede - Responder
Torque Converters are a transmission  problem
Wolfman - Responder
I have an Opel zafira I.8 engine.i observed there is oil spill in the plugs casin surrounding the plugs but not at the mouth of the plugs and this makes the oil short when gauged. Please what can do to this. Thanks
Abdullahi007 - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 70
Ao todo: 5,498
