Ir para o conteúdo principal
How to Clean a Flat Iron
Jacquelin
Jacquelin e 3 outros colaboradores
Última atualização em July 8, 2024
15 minutos
Muito fácil
Introdução
Ir para o passo 1
Does your flat iron not heat up as well as it used to? Does your flat iron have buildup from all the hair product you use? Use this guide to remove accumulated buildup on the plates of your flat iron and improve its heating capabilities.
  1. How to Clean a Flat Iron, How to Clean a Flat Iron: passo 1, imagem 1 %32
    • Lay out your cloth over your working surface.
    • Set flat iron aside.
    • The Flat Iron should never be plugged in while cleaning.
  2. How to Clean a Flat Iron: passo 2, imagem 1 %32 How to Clean a Flat Iron: passo 2, imagem 2 %32
    • Scoop the baking soda (1-3 Tbsp) into your small bowl or cup.
    • You may need more or less baking soda depending on the size of the your iron's plates.
  3. How to Clean a Flat Iron: passo 3, imagem 1 %32 How to Clean a Flat Iron: passo 3, imagem 2 %32
    • Add the hydrogen peroxide to the bowl containing the baking soda and stir until a thick paste is formed.
    • Approximately 10 drops of the hydrogen peroxide is needed per tablespoon of the baking soda.
    • The consistency of the paste should be similar to a thick and grainy toothpaste.
  4. How to Clean a Flat Iron: passo 5, imagem 1 %32 How to Clean a Flat Iron: passo 5, imagem 2 %32
    • Smear a thick layer of the paste onto the plates of the iron.
    • Let sit for 5 minutes.
  5. How to Clean a Flat Iron: passo 6, imagem 1 %32 How to Clean a Flat Iron: passo 6, imagem 2 %32
    • Let the paste sit on the plates for 5 minutes before proceeding.
    • Wipe off the excess but not ALL of the paste with the sponge into the small bowl.
  6. How to Clean a Flat Iron: passo 7, imagem 1 %32
    • Use your cloth or sponge to scrub the plates of the flat iron until all the buildup is removed.
    • This process may take 2-5 minutes depending on the amount of buildup on your iron.
  7. How to Clean a Flat Iron: passo 8, imagem 1 %32
    • Once all of the buildup is removed, wipe off all the remaining paste into your bowl.
  8. How to Clean a Flat Iron: passo 9, imagem 1 %32
    • Dispose the baking soda paste into a sink or trash can.
    • Your Flat Iron is now clean!
Conclusão
Congratulations your flat iron is buildup free!
3 outras pessoas executaram este guia.
Jacquelin
Membro desde: 02/23/15
283 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 12-2, Green Winter 2015 Membro de Cal Poly, Team 12-2, Green Winter 2015
CPSU-GREEN-W15S12G2
6 Membros
Autoria de 14 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 50
Ao todo: 6,099
