Ir para o conteúdo principal
How to Build a Waterproof Pressure Sensor
O que você precisa
  1. How to Build a Waterproof Pressure Sensor, Getting to know your sensor: passo 1, imagem 1 %32
    • This is the pressure sensor that we will be using. It is a STEVAL-MKI183V1 board with a LPS33HW sensor. This board can use either SPI or I2C communications. The data sheets can be accessed here.
  2. How to Build a Waterproof Pressure Sensor, Cut Pins: passo 2, imagem 1 %32
    • The factory pins must be removed and replaced with wire.
    • To do so, first cut along the red line in the photo using wire clipper to separate the pin from the board.
    • Next, clip vertically along the blue line to disconnect the pin from the one next to it.
    • Be very careful while cutting to not damage the board! Rough handling can rip out the copper pad of the through hole, ruining the board.
  3. How to Build a Waterproof Pressure Sensor, Remove the Lead: passo 3, imagem 1 %32
    Ferramenta utilizada neste passo:
    Desoldering Pump
    $3.99
    • The through holes must be cleared of any leftover solder.
    • Place the hot iron on the side of the through hole with the most solder, and the desoldering pump on the other. Once the solder liquefies, press the trigger of the pump to clear the through hole.
    • If you're having trouble with removing solder, it is helpful to use flux dispensing and flux removing pens. Additionally, switching which side the hot iron and the desoldering pump is on helps.
    • Repeat steps 2 and 3 for all of the pins on the board.
  4. How to Build a Waterproof Pressure Sensor, Strip wires: passo 5, imagem 1 %32 How to Build a Waterproof Pressure Sensor, Strip wires: passo 5, imagem 2 %32 How to Build a Waterproof Pressure Sensor, Strip wires: passo 5, imagem 3 %32
    • Use wire strippers to strip the coating of the 4-core shielded wire.
    • Place the wire in the wire stripper. To obtain desired length, align with second jaw or with the blue line in the image.
    • Clamp down to remove the wire coating, leaving the 4 wires remaining
    • Pull out the individual wires and repeat the process for each one, exposing the copper
  5. How to Build a Waterproof Pressure Sensor, Attach Wires: passo 6, imagem 1 %32 How to Build a Waterproof Pressure Sensor, Attach Wires: passo 6, imagem 2 %32 How to Build a Waterproof Pressure Sensor, Attach Wires: passo 6, imagem 3 %32
    • A wire is necessary on the ground, SDA, SDO, SCK, CS, Vd and VdIO pins. These can be identified from the top of the board.
    • Insert the stripped section of the wire into the through hole, and solder into place.
    • Repeat for all seven wires. Electrical tape can cover any exposed shielding if needed.
    • Tip: consider which way you want your wires to run. You can solder them on either side of the board.
  6. How to Build a Waterproof Pressure Sensor, Apply Liquid Electrical Tape: passo 7, imagem 1 %32 How to Build a Waterproof Pressure Sensor, Apply Liquid Electrical Tape: passo 7, imagem 2 %32 How to Build a Waterproof Pressure Sensor, Apply Liquid Electrical Tape: passo 7, imagem 3 %32
    • Apply a layer of liquid electrical tape to the board (a coffee stir stick is a good applicator).
    • After every layer, wait at least ten minutes before applying another one. Very carefully visually inspect to ensure total coverage.
    • Ensure that you do not cover the sensor itself, as it needs to be exposed in order to measure pressure. A small piece of tape can cover and protect the sensor during application.
  7. How to Build a Waterproof Pressure Sensor, Testing Sensor In Water: passo 8, imagem 1 %32 How to Build a Waterproof Pressure Sensor, Testing Sensor In Water: passo 8, imagem 2 %32 How to Build a Waterproof Pressure Sensor, Testing Sensor In Water: passo 8, imagem 3 %32
    • Wire a breadboard as shown in the picture to connect the particle photon to the sensor
    • Important connections: GND is connected to negative rail and GND for sensor. The 3V3 is connected to the positive rail and the Vd, VdIO pins on sensor. A5 is connected to SDA, A4 is connected to SDO, A3 is connected to SCK and A2 is connected to CS.
    • Place in a cup of water and monitor outputs to ensure that a water tight seal was achieved!
Conclusão
If you would like to undo your work, simply peel off the liquid electrical tape (this may be easier with a knife or other sharp edge). Then you are free to alter any of the connections.
Uma outra pessoa concluiu este guia.
Anne George
Membro desde: 11/21/19
163 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 16
Ao todo: 1,224
