Ir para o conteúdo principal
How to Add a Hole to a Belt
Alexa Velazquez
Alexa Velazquez e um outro colaborador
Última atualização em July 24, 2024
5 - 10 minutos
Fácil
Introdução
Ir para o passo 1
Use this guide if you have a belt that is no longer fitting right and has already-made holes and a belt buckle to ensure the guide is used properly.
Belts are only useful as long as they fit well. If you have a belt that no longer fits but you would like to repair it, this guide contains six easy to follow steps that include nothing more extensive than a measuring tape and an electric hand drill.
This guide works best on leather belts and requires no prior repair knowledge. If you are unsure of how to use an electric hand drill as mentioned in steps 3-5 refer here for a demo video briefly explaining the parts of a drill. Once you feel that you are ready, grab the belt you would like to restore and begin the guide.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. How to Add a Hole to a Belt, How to Add a Hole to a Belt: passo 1, imagem 1 %32
    • Wrap the belt around yourself.
    • Mark with a pen, pencil, or marker where the hole should be placed.
  2. How to Add a Hole to a Belt: passo 2, imagem 1 %32 How to Add a Hole to a Belt: passo 2, imagem 2 %32
    • Use a tape measure to center the hole in the middle of the belt.
    • Make sure the hole is in line with the previous hole as well.
  3. How to Add a Hole to a Belt: passo 3, imagem 1 %32
    • Grab a hand drill with a circular bit similar to the size of the current belt holes.
    • For reference, a 5/32 bit was used here.
  4. How to Add a Hole to a Belt: passo 4, imagem 1 %32 How to Add a Hole to a Belt: passo 4, imagem 2 %32
    • Place the belt over a scrap piece of wood or on a material that can be drilled on.
  5. How to Add a Hole to a Belt: passo 5, imagem 1 %32 How to Add a Hole to a Belt: passo 5, imagem 2 %32
    • Drill all the way through the belt where it has been marked.
  6. How to Add a Hole to a Belt: passo 6, imagem 1 %32 How to Add a Hole to a Belt: passo 6, imagem 2 %32
    • Move the drill up and down a few times in place to ensure the hole is smooth around the edges.
    • Be sure the belt buckle fits in the new hole.
Conclusão
After you complete the final step to your liking the fix is done.
Alexa Velazquez
Membro desde: 03/22/21
133 Reputação
Autoria de 1 guia
Equipe
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 16
Últimos 30 dias: 49
Ao todo: 1,741
