Ir para o conteúdo principal
How To Sew With An Awl
Brittany McCrigler
Brittany McCrigler e 3 outros colaboradores
Última atualização em April 8, 2025
15 - 30 minutos
Fácil
Patagonia
Introdução
Ir para o passo 1
An awl is a tool that allows you to sew through very thick materials. It takes a bit of practice to master, but once you have it down you'll be ready to repair boots, webbing, and packs on the fly.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. How To Sew With An Awl, How To Sew With An Awl: passo 1, imagem 1 %32 How To Sew With An Awl, How To Sew With An Awl: passo 1, imagem 2 %32
    • Loosen the awl by holding the smooth end and twisting the ridged piece counterclockwise.
  2. How To Sew With An Awl: passo 2, imagem 1 %32 How To Sew With An Awl: passo 2, imagem 2 %32 How To Sew With An Awl: passo 2, imagem 3 %32
    • Insert the needle into the ridged end of the awl, with the eye facing outward.
    • Retighten the awl by holding the smooth end and twisting the ridged end clockwise.
    • Insert the cotter pin into the hole in the smooth end.
    • The cotter pin provides a nice handle for working with the awl.
  3. How To Sew With An Awl: passo 3, imagem 1 %32 How To Sew With An Awl: passo 3, imagem 2 %32
    • Thread the needle with very thick thread.
    • Align your material. In this case we are resewing the webbing holding a buckle in place.
  4. How To Sew With An Awl: passo 4, imagem 1 %32 How To Sew With An Awl: passo 4, imagem 2 %32
    • Stab the threaded needle of the awl through all the layers of fabric you are sewing.
    • Thick material is very hard to puncture. Be careful not to puncture yourself in the process.
    • If you are having difficulty puncturing the material, you can use a vice to hold the material in place, or place something on the backside of the material to puncture into. A rubber eraser works great.
  5. How To Sew With An Awl: passo 5, imagem 1 %32 How To Sew With An Awl: passo 5, imagem 2 %32
    • Pull the short end of the thread through the material, so that it dangles free on the other side of the material.
  6. How To Sew With An Awl: passo 6, imagem 1 %32 How To Sew With An Awl: passo 6, imagem 2 %32
    • While holding on to the short, free end of the thread, carefully pull the awl back through the material.
    • The short, free end of the thread should stay on the other side of the material.
    • Continue holding the short, free thread, and puncture the material again a short distance away, moving along the material you are sewing.
    • This distance will become a stitch. Try to keep your stitch length short and even.
  7. How To Sew With An Awl: passo 7, imagem 1 %32 How To Sew With An Awl: passo 7, imagem 2 %32 How To Sew With An Awl: passo 7, imagem 3 %32
    • Pull the thread from the eye of the needle, creating a loop.
    • Put the short, free end of the thread through the loop you just created in the thread.
  8. How To Sew With An Awl: passo 8, imagem 1 %32 How To Sew With An Awl: passo 8, imagem 2 %32
    • Holding the short, free end of the thread taught, pull the awl back out through the material.
    • Pull both ends of the thread taught.
  9. How To Sew With An Awl: passo 9, imagem 1 %32 How To Sew With An Awl: passo 9, imagem 2 %32 How To Sew With An Awl: passo 9, imagem 3 %32
    • Continue reinserting the awl, creating a loop of thread from the eye of the needle, threading the short, free end, and removing the awl to create your stitches.
    • While you are getting the hang of it, refer back to steps 6-9 of this guide.
  10. How To Sew With An Awl: passo 10, imagem 1 %32 How To Sew With An Awl: passo 10, imagem 2 %32 How To Sew With An Awl: passo 10, imagem 3 %32
    • When you come to the end of your material, take one last stitch.
    • Clip the end of the thread that runs through the needle, leaving enough length to tie a couple of knots.
    • Remove the awl.
  11. How To Sew With An Awl: passo 11, imagem 1 %32 How To Sew With An Awl: passo 11, imagem 2 %32
    • Tie an overhand knot with the two ends of the thread.
    • Pull taught.
    • Tie another knot or two to secure the stitching.
  12. How To Sew With An Awl: passo 12, imagem 1 %32 How To Sew With An Awl: passo 12, imagem 2 %32
    • Clip the threads, and admire your handiwork.
Linha de Chegada
12 outras pessoas executaram este guia.
Brittany McCrigler
Membro desde: 03/05/12
89.971 Reputação
Autoria de 142 guias
Equipe
iFixit Membro de iFixit
Staff
121 Membros
Autoria de 19.806 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 24
Últimos 30 dias: 117
Ao todo: 19,187
