Ir para o conteúdo principal
How To Replace A Mounted Hose Holder
Bri Garcia
Bri Garcia e 2 outros colaboradores
Última atualização em December 16, 2024
15 - 30 minutos
Moderado
Introdução
Ir para o passo 1
Mounted hose holders are not only helpful for keeping your hose from tangling but they also enhance the aesthetics of your garden/home. Sometimes after a lot of use or depending on the material, they may start to crack from the weight or become loose. If you have a damaged hose holder or you're just ready to upgrade your home's exterior appearance, this guide will walk you through the replacement.
This is a beginner step-by-step replacement requiring minimal tools and knowledge.
  1. How To Replace A Mounted Hose Holder, Mounted Hose Holder: passo 1, imagem 1 %32 How To Replace A Mounted Hose Holder, Mounted Hose Holder: passo 1, imagem 2 %32
    • Remove the water hose from your existing hose holder.
  2. How To Replace A Mounted Hose Holder: passo 2, imagem 1 %32
    • Use an electric drill to remove the old screws from the hose holder.
    • Remove the wall-mounted hose holder.
  3. How To Replace A Mounted Hose Holder: passo 3, imagem 1 %32
    • If your new holder requires more screws than the old one, mark your screw placements first.
  4. How To Replace A Mounted Hose Holder: passo 4, imagem 1 %32
    • If needed, pre-drill any new holes based on your placement marks.
  5. How To Replace A Mounted Hose Holder: passo 5, imagem 1 %32 How To Replace A Mounted Hose Holder: passo 5, imagem 2 %32
    • Align your hose holder with the mounting holes, and position the new nail anchor, washers, and screws into their respective spots.
  6. How To Replace A Mounted Hose Holder: passo 6, imagem 1 %32 How To Replace A Mounted Hose Holder: passo 6, imagem 2 %32 How To Replace A Mounted Hose Holder: passo 6, imagem 3 %32
    • Use an electric drill to drive the new screws through the mount into their placements to secure the hose holder to the wall.
    • Ensure the holder is securely attached.
  7. How To Replace A Mounted Hose Holder: passo 7, imagem 1 %32
    • Loop your hose back on.
Conclusão
Bri Garcia
Membro desde: 09/25/24
157 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 12
Ao todo: 57
