Ir para o conteúdo principal
How To Repair A Couch Cushion
Alexis
Alexis e 3 outros colaboradores
Última atualização em February 19, 2016
15 minutos
Fácil
Introdução
Ir para o passo 1
If you have a ripped cushion that cannot be removed from the couch, use this guide to learn how to repair the hole and prevent the damage from getting worse.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. How To Repair A Couch Cushion, How To Repair A Couch Cushion: passo 1, imagem 1 %32
    • Apply a thin layer of the anti-fray glue to both edges of the rip. Let it dry completely.
  2. How To Repair A Couch Cushion: passo 2, imagem 1 %32
    • Fold the edges of the fabric over to make a clean edge and hide any fraying.
    • Crease the fold with your fingers.
  3. How To Repair A Couch Cushion: passo 3, imagem 1 %32
    • Cut the upholstery thread to a length appropriate for the size of your rip.
    • The thread should match the color of the fabric as closely as possible.
    • Thread the needle and tie a double knot at the end.
  4. How To Repair A Couch Cushion: passo 4, imagem 1 %32 How To Repair A Couch Cushion: passo 4, imagem 2 %32
    • Hold the two edges of the rip together
    • Begin sewing ¾ of an inch from where the rip begins.
    • You might want to use a pin to hold the edges together while you sew
  5. How To Repair A Couch Cushion: passo 5, imagem 1 %32 How To Repair A Couch Cushion: passo 5, imagem 2 %32 How To Repair A Couch Cushion: passo 5, imagem 3 %32
    • Continue sewing until you are past the rip. Knot and cut the excess thread.
Linha de Chegada
3 outras pessoas executaram este guia.
Alexis
Membro desde: 02/24/15
227 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 24-2, Green Winter 2015 Membro de Cal Poly, Team 24-2, Green Winter 2015
CPSU-GREEN-W15S24G2
4 Membros
Autoria de 4 guias
1Comentário do guia
Have you seen this product? "fixmytear". It's a repair tape which sticks very well to vinyl, canvas, rubber, leather and most other surfaces. Absolutely life saving tape.
https://www.amazon.com/Fixmytear-Magic-R...
https://www.amazon.com/fixmytear-Magic-R...
bobhunter50023 - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 46
Ao todo: 17,531
