Ir para o conteúdo principal
How To Remove Bike Rust With Lemon Juice
Eric Robinson
Eric Robinson e 4 outros colaboradores
Última atualização em August 2, 2019
15 - 30 minutos
Fácil
Introdução
Ir para o passo 1
This step-by-step guide will provide the user with a quick and easy way to remove that unappealing rust that builds up on exposed metal parts on bicycle brakes. Unwanted rust can inhibit the proper function of your brakes. This guide can be used on a variety of bike brakes which has exposed metal parts and is susceptible to rust.
O que você precisa
A iFixit ganha comissão quando você compra por estes links.
  1. How To Remove Bike Rust With Lemon Juice, How To Remove Bike Rust With Lemon Juice: passo 1, imagem 1 %32 How To Remove Bike Rust With Lemon Juice, How To Remove Bike Rust With Lemon Juice: passo 1, imagem 2 %32
    • Put on Latex gloves
  2. How To Remove Bike Rust With Lemon Juice: passo 2, imagem 1 %32
    • Generously apply the lime juice onto steel wool
    • Keep the lime juice out of eyes and any open wounds due to the acidic qualities of the lime juice
  3. How To Remove Bike Rust With Lemon Juice: passo 3, imagem 1 %32 How To Remove Bike Rust With Lemon Juice: passo 3, imagem 2 %32 How To Remove Bike Rust With Lemon Juice: passo 3, imagem 3 %32
    • Vigorously rub the steel wool with lime juice on the rusty parts of the brakes
  4. How To Remove Bike Rust With Lemon Juice: passo 4, imagem 1 %32
    • Wipe off the excess lime juice and the removed rust particles with paper towels to make your bike brakes look as good as new!
Conclusão
After the user has completed these 4 simple steps, the exposed metal parts should be free of rust and ready to use. Repeat these steps for any other rusty metal parts of bicycle brakes.
9 outras pessoas executaram este guia.
Eric Robinson
Membro desde: 04/09/15
485 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 30-2, Green Spring 2015 Membro de Cal Poly, Team 30-2, Green Spring 2015
CPSU-GREEN-S15S30G2
4 Membros
Autoria de 4 guias
1Comentário do guia
the title says Lemon Juice, while all the references inside refer to Lime Juice.
richardwstevens - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 28
Ao todo: 3,443
