Ir para o conteúdo principal
How To Patch a Hole in Umbrella Fabric
Brandon Hillert
Brandon Hillert e 2 outros colaboradores
Última atualização em May 13, 2024
15 - 25 minutos
Fácil
Introdução
Ir para o passo 1
Umbrellas are a basic tool that most people need in their everyday lives. They get damaged from continuous use or from getting snagged on something sharp during use or transport. Instead of repeatedly buying new ones, we suggest that you fix your old umbrella, as the process is simple and can be done by someone with little to no experience. This guide will show users how to repair a tear in an umbrella by mending it with a needle and thread and reinforcing it with a fabric patch.
  1. How To Patch a Hole in Umbrella Fabric, Fabric: passo 1, imagem 1 %32
    • Remove the fabric from the extender arms of your umbrella.
    • This allows you to more easily work with the torn area, as the fabric won't be held tightly.
  2. How To Patch a Hole in Umbrella Fabric: passo 2, imagem 1 %32
    • Sew the tear together from the back side of the umbrella using your needle and nylon thread.
    • Be sure to use a thin gauge nylon thread, as cotton threads will soak through and cause leaks in your canopy.
  3. How To Patch a Hole in Umbrella Fabric: passo 3, imagem 1 %32
    • Cut your patch to an appropriate size relative to the tear.
    • The size of your patch should be big enough to completely cover the tear, with around an inch of additional material on all sides.
  4. How To Patch a Hole in Umbrella Fabric: passo 4, imagem 1 %32
    • Apply your fabric glue to the backside of your patch material.
  5. How To Patch a Hole in Umbrella Fabric: passo 5, imagem 1 %32
    • Lay the torn area of the fabric on a flat surface.
  6. How To Patch a Hole in Umbrella Fabric: passo 6, imagem 1 %32
    • Apply your patch squarely over the torn fabric.
Conclusão
To reassemble your umbrella, reattach the fabric to the rivets that you disconnected it from.
Brandon Hillert
Membro desde: 10/04/20
133 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 70
Últimos 30 dias: 307
Ao todo: 17,075
