Ir para o conteúdo principal
How To Hem Pants With Double-Sided Fabric Tape
Allison
Allison e um outro colaborador
Última atualização em August 26, 2024
20 minutos
Moderada
Are you tired of pant legs that are too long and get caught under your shoes, causing you to trip or stumble? What if I told you all you needed was some double-sided fabric tape, iron or press, and a ruler to hem up those pants?
  1. How To Hem Pants With Double-Sided Fabric Tape, How To Hem Pants With Double-Sided Fabric Tape: passo 1, imagem 1 %32
    • First, you want to try on the pants that need hemming.
  2. How To Hem Pants With Double-Sided Fabric Tape: passo 2, imagem 1 %32
    • Fold up the pants to the desired length you would like.
  3. How To Hem Pants With Double-Sided Fabric Tape: passo 3, imagem 1 %32
    • Use a ruler to make sure the length is the same all around.
  4. How To Hem Pants With Double-Sided Fabric Tape: passo 4, imagem 1 %32
    • Use a washable chalk marker to mark where you want the pant leg to come up to.
  5. How To Hem Pants With Double-Sided Fabric Tape: passo 5, imagem 1 %32
    • Fold up the pants to the desired length using the chalk line as your guide.
  6. How To Hem Pants With Double-Sided Fabric Tape: passo 6, imagem 1 %32
    • Use an iron or press to create a fold or crease in the pants to the desired length marked by the chalk.
  7. How To Hem Pants With Double-Sided Fabric Tape: passo 7, imagem 1 %32
    • Creating a fold or crease will help keep your pant length the same on all sides.
  8. How To Hem Pants With Double-Sided Fabric Tape: passo 8, imagem 1 %32
    • Place the double-sided fabric tape on the edge of the pant legs.
    • I used a total of 4 - 1/2"x3" strips for each pant leg.
  9. How To Hem Pants With Double-Sided Fabric Tape: passo 9, imagem 1 %32
    • Press firmly for about 10 seconds on the tape to make sure it sticks to the pant leg.
  10. How To Hem Pants With Double-Sided Fabric Tape: passo 10, imagem 1 %32
    • Remove the remaining backing of the tape.
  11. How To Hem Pants With Double-Sided Fabric Tape: passo 11, imagem 1 %32
    • Press firmly on all sides of the pants for about 10 seconds to make sure the tape adheres to all sides.
  12. How To Hem Pants With Double-Sided Fabric Tape: passo 12, imagem 1 %32
    • Try on the pants one last time to make sure they are the desired length to prevent you from tripping over them.
Conclusão
You don't need a sewing machine to hem a pair of overly long pants.
Allison
Membro desde: 10/07/23
205 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 13
Últimos 30 dias: 55
Duração total: 843
