Introdução
Are you about to throw away your bookshelf due to loose screws? Do you want to save money and time? If the old screws do not properly hold the wooden boards together (and you feel they may fall apart soon), it is time to fix your bookshelf in a few simple steps.
O que você precisa
If the distance between the screw and the edge is less than 1/8", move to Step 2.
If the distance is more than 1/8", take the wider sized screw (min. +1/32") and use the screwdriver to screw the boards back together.
To reassemble your device, follow the instructions that came with the bookshelf, or follow these steps in reverse order.
2 outras pessoas concluíram este guia.
