Ir para o conteúdo principal
Hot Tools HPK12 Prerequisite Only
Aaron Whitlock
Aaron Whitlock e 9 outros colaboradores
Última atualização em March 5, 2018
20 minutos
Moderada
Pré-requisito somente
Este guia destina-se apenas a ser usado como pré-requisito para outros guias. É incompleto por si só.
In this replacement guide, we will walk you through the first steps to take to replace most things on your Hot Tools HPK12 flat iron. Be sure to have the device powered off, unplugged, and completely cooled down before beginning.
O que você precisa
Ferramentas
Exibir mais…
  1. Hot Tools HPK12 Prerequisite Only, Prerequisite Only: passo 1, imagem 1 %32 Hot Tools HPK12 Prerequisite Only, Prerequisite Only: passo 1, imagem 2 %32 Hot Tools HPK12 Prerequisite Only, Prerequisite Only: passo 1, imagem 3 %32
    • Remove round plastic cover near cord base by prying under the side with the metal spudger.
    • Flip the device and remove the other round plastic cover near the base of the cord.
    • Use the Phillips #1 screwdriver to remove the 5.5mm PH1 screw and washer under the plastic cover and set both aside.
  2. Hot Tools HPK12 Prerequisite Only: passo 2, imagem 1 %32
    • Use the metal spudger to push the center pin through to the other side.
  3. Hot Tools HPK12 Prerequisite Only: passo 3, imagem 1 %32 Hot Tools HPK12 Prerequisite Only: passo 3, imagem 2 %32
    • Lift back plastic cover to expose spring assembly.
    • Be careful not to damage the power cord by bending or twisting it too much while performing this step.
    • Grip the exposed end of the spring assembly and remove it.
    • The side with the two ends of the spring goes into the recessed area of the iron
  4. Hot Tools HPK12 Prerequisite Only: passo 4, imagem 1 %32
    • Use the JIS #0 screwdriver to remove the two 3.5mm “J0” screws that attach the control assembly cover to the flat iron base.
  5. Hot Tools HPK12 Prerequisite Only: passo 5, imagem 1 %32 Hot Tools HPK12 Prerequisite Only: passo 5, imagem 2 %32 Hot Tools HPK12 Prerequisite Only: passo 5, imagem 3 %32
    • Lift upward on the control assembly cover to remove it from the flat iron base.
    • Remove dial and switch cover and set aside.
  6. Hot Tools HPK12 Prerequisite Only: passo 6, imagem 1 %32 Hot Tools HPK12 Prerequisite Only: passo 6, imagem 2 %32 Hot Tools HPK12 Prerequisite Only: passo 6, imagem 3 %32
    • Use your JIS #0 screw driver to remove the two 6mm “J0” screws that are attached to the flat iron base and set them aside.
    • Lift the backing plate upwards to remove it from the flat iron.
    • Use the Phillips #0 screwdriver to remove two 4mm “PH0” screws that attach the circuit assembly to the flat iron base.
Conclusão
Aaron Whitlock
Membro desde: 10/24/16
249 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 3-4, Baechle Fall 2016 Membro de IUPUI, Team 3-4, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G4
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 13
Últimos 30 dias: 24
Duração total: 118
