Ir para o conteúdo principal
Hoover LiNX Power Button Replacement
Mark Nelson
Mark Nelson e 2 outros colaboradores
Última atualização em August 20, 2022
10 - 15 minutos
Fácil
Introdução
Ir para o passo 1
This guide will show you how to replace the internal switch inside the handle. This guide will be identical to the motherboard guide with a few extra steps. This would be needed if the power button is no longer working in the handle.
O que você precisa
Ferramentas
Exibir mais…
  1. Hoover LiNX Power Button Replacement, Hoover LiNX Handle Teardown: passo 1, imagem 1 %32
    • Remove the single 15mm Phillips #1 screw from the handle.
  2. Hoover LiNX Power Button Replacement: passo 2, imagem 1 %32
    • Remove the handle by pulling it up.
  3. Hoover LiNX Power Button Replacement: passo 3, imagem 1 %32
    • Remove two 15mm Phillips #1 screws from the handle.
  4. Hoover LiNX Power Button Replacement: passo 4, imagem 1 %32 Hoover LiNX Power Button Replacement: passo 4, imagem 2 %32
    • Use a plastic opening tool to carefully pry the black cover off of the handle.
  5. Hoover LiNX Power Button Replacement: passo 5, imagem 1 %32 Hoover LiNX Power Button Replacement: passo 5, imagem 2 %32
    • Remove five 15mm Phillips #1 black screws from the handle.
  6. Hoover LiNX Power Button Replacement: passo 6, imagem 1 %32 Hoover LiNX Power Button Replacement: passo 6, imagem 2 %32
    • Remove the silver plastic cover using the plastic opening tool.
  7. Hoover LiNX Power Button Replacement, The Motherboard Inside The Handle: passo 7, imagem 1 %32
    • Remove the black rubber cover from the motherboard.
  8. Hoover LiNX Power Button Replacement: passo 8, imagem 1 %32
    • Remove two 8mm Phillips #1 screws from the motherboard.
  9. Hoover LiNX Power Button Replacement: passo 9, imagem 1 %32 Hoover LiNX Power Button Replacement: passo 9, imagem 2 %32
    • Carefully pull the motherboard out with its attached wires.
  10. Hoover LiNX Power Button Replacement, Power Button: passo 10, imagem 1 %32 Hoover LiNX Power Button Replacement, Power Button: passo 10, imagem 2 %32
    • Replace the power button.
Conclusão
Mark Nelson
Membro desde: 01/25/18
452 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team S7-G4, Passmore Spring 2018 Membro de USF Tampa, Team S7-G4, Passmore Spring 2018
USFT-PASSMORE-S18S7G4
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 1,381
