Honeywell HY-204 Control Panel Replacement
Introdução
Ir para o passo 1This guide is necessary to complete before many of our other replacement guides, but it can also stand alone as a replacement guide for the control panel. This is a really simple guide and should only take you a few minutes!
O que você precisa
Ferramentas
Remove the four 14 mm screws from the back of the device using the Phillips #0 Screwdriver.
Remove the two 3mm screws found just below the top of the device using the Phillips #0 Screwdriver.
