Hipstreet Titan Plus Motherboard Replacement
Introdução
Vá para o passo 1This motherboard replacement guide will walk you through the steps on how to remove necessary components in order to get to the motherboard. Replacing the motherboard is a moderate, four-step process using necessary tools, including a soldering iron.
O que você precisa
Ferramentas
Exibir mais…
Use the plastic opening tools to pry the screen from the back of the device.
Uma outra pessoa concluiu este guia.
