HTC One V Vibrator Replacement
Introdução
Vá para o passo 1If phone will not vibrate, vibrates slightly or vibrates sometimes, a faulty vibrator could be the issue.
O que você precisa
Power off your device.
Remove the bottom cover by sliding it off.
Use the plastic opening tool to pry open the rear camera panel.
Remove both screws that are securing the back case.
One 4.0 mm Phillips #0 screw.
One 3.0 mm Phillips #0 screw.
Remove the two 3.0 mm Phillips #0 screws, that are securing the camera lens.
Ferramenta utilizada neste passo:Tweezers$4.99
Pry the vibrator out of the housing with a spudger.
Using the tweezers, pull up on the connecting wires detaching the vibrator from the motherboard.
