Ir para o conteúdo principal
HP Probook 6450b Fan Cleaning & Thermal Paste Replacement
Carolyn Teng
Carolyn Teng e 4 outros colaboradores
Última atualização em January 3, 2024
30 minutos - 1 hora
Moderada
Is your laptop constantly overheating and shutting off? This could be due to a clogged vent fan and/or burnt out thermal paste on your heat sink. Thermal paste is a conductive paste that allows heat to transfer from the electrical components in your laptop to the heat sink, and ultimately out of the computer. Save yourself some money, and learn how to keep your laptop nice and cool with this guide.
O que você precisa
Fix Kit
Este kit contém todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. HP Probook 6450b Fan Cleaning & Thermal Paste Replacement, HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 1, imagem 1 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement, HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 1, imagem 2 %32
    • Shut down your laptop completely.
    • Do not simply power off your computer using the power button. This will put the laptop into sleep mode. Instead, shut down the laptop from the start menu.
    • Unplug the charger cord and all devices connected to the computer.
  2. HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 2, imagem 1 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 2, imagem 2 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 2, imagem 3 %32
    • Flip the laptop over and locate the battery compartment release latch.
    • Slide the release latch to the left to release the battery.
  3. HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 3, imagem 1 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 3, imagem 2 %32
    • Remove the battery.
  4. HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 4, imagem 1 %32
    • Electrostatic shocks can damage the internal components of the computer.
    • Press and hold the power button for a minimum of 10 seconds to allow electric charge to dissipate from the motherboard and internal components.
    • Optional: You may also wear an anti-static bracelet during the repair as a safety precaution. This grounds you to the computer chassis and prevents accidental static discharge from your fingers.
  5. HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 5, imagem 1 %32
    • Locate and loosen the 3 Phillips PM 2.5 x 11.0 screws on the bottom side of the computer.
  6. HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 6, imagem 1 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 6, imagem 2 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 6, imagem 3 %32
    • Flip the laptop right side up and open the screen.
    • Locate the 4 keyboard tabs. Slide the tabs towards you.
  7. HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 7, imagem 1 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 7, imagem 2 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 7, imagem 3 %32
    • Lift the keyboard by the upper edge, then flip it over so the ribbon cable is exposed.
    • Do not attempt to remove the keyboard until the ribbon cable has been disconnected.
  8. HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 8, imagem 1 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 8, imagem 2 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 8, imagem 3 %32
    • Lift both ends of the plastic tab securing the ribbon cable to the system board with the help of a spudger.
    • If you don't have a spudger, any plastic item with a thin edge, like the plastic opening tool pictured here, will work just as well. Guitar picks are also a good alternative.
  9. HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 9, imagem 1 %32
    • Remove the keyboard ribbon cable and set the keyboard aside.
  10. HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 10, imagem 1 %32
    • Close the laptop and turn it upside down.
    • Remove the 3 PM 2.0 x 3.0 screws securing the switch cover.
  11. HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 11, imagem 1 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 11, imagem 2 %32
    • Flip the laptop right side up, and open the display.
    • Locate the LED board ribbon cable. Lift both ends of the plastic tab securing the ribbon cable to the system board.
    • Slide out the LED board ribbon cable.
  12. HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 12, imagem 1 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 12, imagem 2 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 12, imagem 3 %32
    • Remove the switch cover.
    • You may need to use the spudger or opening tool to pry open the switch cover. It is easiest to start from the top edge, closest to the screen.
  13. HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 13, imagem 1 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 13, imagem 2 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 13, imagem 3 %32
    • Locate and loosen the 2 slotted Torx T8M 2.5 x 7.0 screws securing the fan to the motherboard.
    • Disconnect the fan cable from the board.
  14. HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 14, imagem 1 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 14, imagem 2 %32
    • Lift out vent fan.
    • Clean the dust from the fan with a small brush and/or compressed air.
    • When using compressed air, avoid tilting the bottle greater than 40 degrees from vertical. Doing so will cause the part and your hand to rapidly cool.
  15. HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 15, imagem 1 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 15, imagem 2 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 15, imagem 3 %32
    • Locate and loosen the 4 Phillips PM 2.5 x 9.0 screws securing the heat sink.
    • You may wish to disconnect the cable adjacent to the heat sink, to make removal easier.
  16. HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 16, imagem 1 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 16, imagem 2 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 16, imagem 3 %32
    • The thermal paste may have stuck the heat sink to the motherboard. Gently jimmy the heat sink back and forth until it is loose.
    • Extract the heat sink.
  17. HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 17, imagem 1 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 17, imagem 2 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 17, imagem 3 %32
    • Remove dust trapped in the heat sink vent with compressed air and/or a small brush.
  18. HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 18, imagem 1 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 18, imagem 2 %32
    • Remove the old thermal paste from the heat sink and the CPU with a lint free wipe or cotton swab dipped in rubbing alcohol.
  19. HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 19, imagem 1 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 19, imagem 2 %32
    • Allow the rubbing alcohol to dry completely.
    • Squeeze a small quantity of thermal paste onto the component's surface. The gobs should be about the size of a grain of rice.
  20. HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 20, imagem 1 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 20, imagem 2 %32 HP Probook 6450b Fan Cleaning & Thermal Paste Replacement: passo 20, imagem 3 %32
    • Reinsert the heat sink into the laptop. Tighten the screws to secure it into place.
Conclusão
24 outras pessoas executaram este guia.
Carolyn Teng
Membro desde: 02/24/15
931 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 23-4, Green Winter 2015 Membro de Cal Poly, Team 23-4, Green Winter 2015
CPSU-GREEN-W15S23G4
Membros da 7
Autoria de 15 guias
5 comentários
I didn't think i would find a guide for my 6540b let alone the exact procedure I need. Thanks a million!
tech4eleven - Responder
Awesome tutorial! Cleaned mine pretty quick.
Dawn Eckel - Responder
Your instructions are very helpful. Thank you
Stanford Kaswera - Responder
I have cleaned it all and all went well but on start up I have a blank screen.
Any help?
Fred Paul - Responder
Fred Paul try re seating or replacing ram.Also check .LCD ribbon cable.
Michael - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 30
Últimos 30 dias: 68
Duração total: 16,297
