Ir para o conteúdo principal
HP Pavilion x360 15t-br000 Hard Drive Replacement
xi yang
xi yang e 6 outros colaboradores
Última atualização em January 17, 2025
10 minutos
Fácil
Precisa de melhores imagens
Precisa de mais images
If there is something wrong with the hard drive of your HP Pavilion x360 15t-br000, you may need this repair guide page for checking and taking it out from inside your computer.
The hard drive serves as a core role in the computer system. Whenever you find it works in the wrong way, you should first try your best to find where the problem is. You could do it by watching (If there is any external or structural damage), listening (If it is working smoothly) or feeling the change of its temperature. However, the first step to do is to take the hard drive out of your computer.
The guide does not include images or steps to remove the hard drive, since the hard drive was not present in our device.
O que você precisa
Ferramentas
  1. HP Pavilion x360 15t-br000 Hard Drive Replacement, Keyboard Panel: passo 1, imagem 1 %32 HP Pavilion x360 15t-br000 Hard Drive Replacement, Keyboard Panel: passo 1, imagem 2 %32 HP Pavilion x360 15t-br000 Hard Drive Replacement, Keyboard Panel: passo 1, imagem 3 %32
    • Remove the covers to access the screws attached to the back cover of the device.
    • Remove six 3mm screws using the Phillips #0 screwdriver.
  2. HP Pavilion x360 15t-br000 Hard Drive Replacement: passo 2, imagem 1 %32 HP Pavilion x360 15t-br000 Hard Drive Replacement: passo 2, imagem 2 %32 HP Pavilion x360 15t-br000 Hard Drive Replacement: passo 2, imagem 3 %32
    • Use a metal spudger to loosen the four corners of the keyboard panel. The corner is circled red as shown in the first image.
    • Disconnect the keyboard panel cables under the upper case.
    • Remove the keyboard panel from the device.
  3. HP Pavilion x360 15t-br000 Hard Drive Replacement, Hard Drive: passo 3, imagem 1 %32
    • Use the Phillips #0 screwdriver to remove four screws from the hard drive.
    • Remove the hard drive from the device.
    • At the time of creating this guide, the hard drive was not present in the device.
Conclusão
Uma outra pessoa concluiu este guia.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 17
Duração total: 924
