HP Pavilion dv6000 RAM Replacement
Introdução
Ir para o passo 1If you need more memory because your computer is running slowly, or you are having memory problems, the RAM is very easy to replace in the HP Pavilion dv6000.
O que você precisa
Remove the two screws from the memory shield and lift up. The screws will remain into the shield
18 outras pessoas executaram este guia.
3 comentários
if you have bios version f.25 or newer you can have up to 4gb of ram
2+2 or 4+4 ? which one?
That is pretty helpful. I think I am going to update my bios, not to mention the article forgot to mention to have a DDR2 ram. Just make sure to look for a DDR2 PC2- 5300 version with 667 MHz.
Tommy E. -
