Ir para o conteúdo principal
HP Pavilion Touchsmart 11z-e000 WLAN Card Replacement
Nguyen
Nguyen e 6 outros colaboradores
Última atualização em June 17, 2015
15 - 30 minutos
Moderado
Introdução
Ir para o passo 1
If your wi-fi keeps disconnecting or cannot connect at all even when other devices work properly, consider replacing your wireless card.
O que você precisa
Ferramentas
  1. HP Pavilion Touchsmart 11z-e000 WLAN Card Replacement, Battery: passo 1, imagem 1 %32
    • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
  2. HP Pavilion Touchsmart 11z-e000 WLAN Card Replacement, Remove back plate: passo 2, imagem 1 %32
    • Using a spudger, pry the plastic plate off of the base of the computer.
  3. HP Pavilion Touchsmart 11z-e000 WLAN Card Replacement, Remove screws: passo 3, imagem 1 %32
    • Remove the screws from the WLAN card
  4. HP Pavilion Touchsmart 11z-e000 WLAN Card Replacement, Remove WLAN card: passo 4, imagem 1 %32
    • Remove the card by sliding out of the slot.
  5. HP Pavilion Touchsmart 11z-e000 WLAN Card Replacement, Disconnect the cables: passo 5, imagem 1 %32
    • Remove the cables from their connections by pulling them off. They should snap on and off.
Conclusão
Nguyen
Membro desde: 01/22/15
301 Reputação
Autoria de 2 guias
Equipe
Cal Poly, Team 21-22, Maness Winter 2015 Membro de Cal Poly, Team 21-22, Maness Winter 2015
CPSU-MANESS-W15S21G22
4 Membros
Autoria de 6 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 8
Ao todo: 468
