HP Pavilion Touchsmart 11z-e000 Fan Replacement
Introdução
Ir para o passo 1The fan is a key component to the laptop in that it draws cool air into the laptop and expels hot air. A functioning fan helps the computer perform well by preventing components in the laptop from overheating.
O que você precisa
Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
Slide a spudger under the outer plastic cover of the laptop.
Pry the outer plastic cover off of the laptop, one side at a time.
