Introdução
The case contains all the internal parts of the laptop. It will need to be opened to replace these parts. This guide will serve as a general procedure on how to open up the laptop case in order to perform the other replacement guides.
Peças
Nenhum componente especificado.
Using the spudger to lift up on the white tabs
Pull horizontally on the blue ribbon to disconnect the cables
Uma outra pessoa concluiu este guia.
