HP Pavilion G60-247CL Speaker Replacement
Introdução
Ir para o passo 1If your HP Pavilion G60-247CL's speaker is malfunctioning, it may be time to replace your speaker. This guide will show you how. Proceed with caution when taking apart the laptop and when removing wires, which is required to complete this task. Specifications are not needed for this guide. Turn off your device before you start.
O que você precisa
Press down and to the right on the battery lock slide.
Once slid over to the right the battery will pop up and out.
Remove the battery and RAM.
Locate the hard drive access panel.
Remove the two 1.2mm Phillips #1 screws on the hard drive access panel.
