HP Pavilion G60-247CL Fan Replacement
Introdução
Ir para o passo 1This guide will show you how to replace the fan of the HP Pavilion G60-247CL.
O que você precisa
Ferramentas
Exibir mais…
Press down and to the right on the battery lock slide.
Once slid over to the right the battery will pop up and out.
Remove the battery and RAM.
Locate the hard drive access panel.
Remove the two 1.2mm Phillips #1 screws on the hard drive access panel.
Locate the fan in the top left corner.
Carefully disconnect the wire attached to the motherboard using your fingers.
