Ir para o conteúdo principal
HP Pavilion 15-bk020wm Keyboard Cover Replacement
Meshayla Block
Meshayla Block e 4 outros colaboradores
Última atualização em May 25, 2021
5 minutos
Fácil
This guide will assist you in replacing the keyboard cover on your HP Pavilion 15-bk020wm device. Your device might need this replacement due to rough handling. This is also a prerequisite guide for further device dismantling.
O que você precisa
Peças
Ferramentas
  • iFixit Opening Tool
    iFixit Opening Tool
  • Phillips #00 Screwdriver
  • Spudger
    Spudger
Exibir mais…
  1. HP Pavilion 15-bk020wm Keyboard Cover Replacement, Keyboard Cover: passo 1, imagem 1 %32 HP Pavilion 15-bk020wm Keyboard Cover Replacement, Keyboard Cover: passo 1, imagem 2 %32
    • Before you begin, turn the laptop off and unplug it from the power source.
    • Remove the 4 computer feet. (Our device didn't have these; they can be taken off with a plastic spudger.)
    • Remove the two screw cover strips.
    • Remove the two screw cover plugs.
    • Unscrew all 12 screws (size: Phillips M2.5×7.0 ) from the bottom of the computer.
  2. HP Pavilion 15-bk020wm Keyboard Cover Replacement: passo 2, imagem 1 %32 HP Pavilion 15-bk020wm Keyboard Cover Replacement: passo 2, imagem 2 %32 HP Pavilion 15-bk020wm Keyboard Cover Replacement: passo 2, imagem 3 %32
    • Turn the computer over to the front.
    • Open the laptop.
    • Use a plastic pry tool to pry up the keyboard cover near the hinge on both the right and left side, and work your way towards the touchpad.
  3. HP Pavilion 15-bk020wm Keyboard Cover Replacement: passo 3, imagem 1 %32
    • Tilt the keyboard cover up slightly.
    • Do not fully remove the keyboard, as it is still attached to the laptop by some cables.
Conclusão
Um comentário
two questions
Where can i get these tools?
Will these instructions work for HP Notebook - 15-db0019au ?
craftcove - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 15
Últimos 30 dias: 54
Duração total: 13,448
