HP Pavilion 15-bk020wm Hard Drive Replacement
Introdução
Vá para o passo 1Your stock hard drive could be too slow for your operating software. Use this guide to replace your current hard drive with one of larger capacity.
O que você precisa
Kits de conserto
Estes kits contêm todas as peças e ferramentas necessárias para executar este guia.
Peças
Ferramentas
Exibir mais…
Remove the 4 computer feet. (Our device didn't have these; they can be taken off with a plastic spudger.)
Remove the two screw cover strips.
Remove the two screw cover plugs.
Unscrew all 12 screws (size: Phillips M2.5×7.0 ) from the bottom of the computer.
3 outras pessoas executaram este guia.
