Ir para o conteúdo principal
HP Pavilion 15-ba003ds Disc Drive Removal
Kristen Gismondi
Kristen Gismondi e 2 outros colaboradores
Última atualização em March 7, 2025
5 - 10 minutos
Muito fácil
Estudante em progresso
Melhor Introdução
Faltando detalhes
If your HP Pavilion 15-ba003ds disc drive is making unusual clicking sounds or failing to read discs properly, you may be dealing with a faulty drive. This could be caused by a dirty lens covered in dust, preventing the drive from reading the disc and causing it to repeatedly search for it.
If cleaning the lens doesn't fix the issue, this guide will provide you with step-by-step instructions on safely accessing and removing the Disc Drive.
Before beginning the repair, make sure to find your laptop's model name, product number, and serial number. You can locate these on a sticker at the bottom of your device or behind the battery on some models. The model name will look like "Pavilion 15-bxxxxxx," while the product number will consist of letters and numbers, such as "D8X43UA." These details are important for finding the right drivers and getting support.
Whether you're replacing a faulty drive or upgrading to a new one, these instructions will help you complete the process.
Be sure to power down your device before starting to prevent any potential damage or safety hazards.
O que você precisa
Ferramentas
  1. HP Pavilion 15-ba003ds Disc Drive Removal, Battery: passo 1, imagem 1 %32 HP Pavilion 15-ba003ds Disc Drive Removal, Battery: passo 1, imagem 2 %32
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Disc Drive Removal, Disc Drive: passo 2, imagem 1 %32
    • Remove the two rubber feet next to the battery.
  3. HP Pavilion 15-ba003ds Disc Drive Removal: passo 3, imagem 1 %32 HP Pavilion 15-ba003ds Disc Drive Removal: passo 3, imagem 2 %32
    • There are twelve 8mm screws in total that need to be unscrewed
    • Using a Phillips #00 screwdriver, unscrew them all including the two screws found underneath the rubber feet.
  4. HP Pavilion 15-ba003ds Disc Drive Removal: passo 4, imagem 1 %32 HP Pavilion 15-ba003ds Disc Drive Removal: passo 4, imagem 2 %32
    • Once all twelve screws are removed the disc drive can now be gently pulled out by hand.
Conclusão
Kristen Gismondi
Membro desde: 11/12/14
92.099 Reputação
Autoria de 241 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 118
Autoria de 19.459 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 41
Duração total: 166
