Ir para o conteúdo principal
HP Pavilion 15-ba003ds Battery Replacement
Joseph Chia
Joseph Chia e 3 outros colaboradores
Última atualização em February 25, 2025
1 minuto
Muito fácil
Estudante em progresso
This guide will detail how you can remove the external battery attached to your HP Pavilion 15-ba003ds. You can follow these steps to safely remove your battery and attach a new one. This guide may be of use to you if you’d like to replace your battery.
  1. HP Pavilion 15-ba003ds Battery Replacement, Battery: passo 1, imagem 1 %32 HP Pavilion 15-ba003ds Battery Replacement, Battery: passo 1, imagem 2 %32
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
Conclusão
Joseph Chia
Membro desde: 01/14/20
355 Reputação
Autoria de 3 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 9
Duração total: 236
