Ir para o conteúdo principal
HP Pavilion 15-b109wm Motherboard Replacement
Enrico Miozzo
Enrico Miozzo e 3 outros colaboradores
Última atualização em January 7, 2020
25 - 35 minutos
Difícil
This replacement guide will show how to replace the Motherboard of an HP Pavilion 15-b109wm. This process will take between 25-35 minutes, if done correctly. Remember to take your time and do the steps correctly and gently to avoid parts breakage.
For this guide you will need a heavy-duty spudger, a JIS driver set and an iFixtit opening tool. Some parts of this guide require some force to pop open, be careful not to brake or damage any parts when applying force.
O que você precisa
Ferramentas
Exibir mais…
  1. HP Pavilion 15-b109wm Motherboard Replacement, Hard Drive: passo 1, imagem 1 %32 HP Pavilion 15-b109wm Motherboard Replacement, Hard Drive: passo 1, imagem 2 %32 HP Pavilion 15-b109wm Motherboard Replacement, Hard Drive: passo 1, imagem 3 %32
    • Disconnect the cables to the motherboard.
  2. HP Pavilion 15-b109wm Motherboard Replacement: passo 2, imagem 1 %32 HP Pavilion 15-b109wm Motherboard Replacement: passo 2, imagem 2 %32
    • Remove the hard drive.
  3. HP Pavilion 15-b109wm Motherboard Replacement, Motherboard: passo 3, imagem 1 %32 HP Pavilion 15-b109wm Motherboard Replacement, Motherboard: passo 3, imagem 2 %32
    • Unclip the WLAN cable out of its place to allow the motherboard room to move.
  4. HP Pavilion 15-b109wm Motherboard Replacement: passo 4, imagem 1 %32 HP Pavilion 15-b109wm Motherboard Replacement: passo 4, imagem 2 %32
    • Detach the power connector cable.
  5. HP Pavilion 15-b109wm Motherboard Replacement: passo 5, imagem 1 %32 HP Pavilion 15-b109wm Motherboard Replacement: passo 5, imagem 2 %32
    • Remove the motherboard from the device.
Conclusão
To reassemble your device work in the reverse order, make sure all the screws are in their required hole before assembling the next part.
Enrico Miozzo
Membro desde: 11/07/19
244 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S2-G4, Harley Fall 2019 Membro de IUPUI, Team S2-G4, Harley Fall 2019
IUPUI-HARLEY-F19S2G4
Membros da 3
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 366
