Ir para o conteúdo principal
HP Pavilion 15-ab165us Fan Replacement
Chad Christy
Chad Christy e um outro colaborador
Última atualização em January 7, 2020
10 - 15 minutos
Moderado
Precisa de melhores imagens
Introdução
Ir para o passo 1
This guide highlights the removal/replacement of the HP Pavilion 15-ab165us fan. The fan is a part used in electronics to dissipate heat out of the device. When the fan becomes damaged or the device stays at high temperature levels, it is recommended to replace the fan.
O que você precisa
Ferramentas
Exibir mais…
  1. HP Pavilion 15-ab165us Fan Replacement, Battery and Back Cover: passo 1, imagem 1 %32 HP Pavilion 15-ab165us Fan Replacement, Battery and Back Cover: passo 1, imagem 2 %32
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Fan Replacement: passo 2, imagem 1 %32 HP Pavilion 15-ab165us Fan Replacement: passo 2, imagem 2 %32 HP Pavilion 15-ab165us Fan Replacement: passo 2, imagem 3 %32
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Fan Replacement: passo 3, imagem 1 %32 HP Pavilion 15-ab165us Fan Replacement: passo 3, imagem 2 %32 HP Pavilion 15-ab165us Fan Replacement: passo 3, imagem 3 %32
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Fan Replacement: passo 4, imagem 1 %32
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Fan Replacement: passo 5, imagem 1 %32
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Fan Replacement: passo 6, imagem 1 %32
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Fan Replacement: passo 7, imagem 1 %32 HP Pavilion 15-ab165us Fan Replacement: passo 7, imagem 2 %32
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Fan Replacement: passo 8, imagem 1 %32
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
  9. HP Pavilion 15-ab165us Fan Replacement, Fan: passo 9, imagem 1 %32
    • Disconnect the fan from the motherboard.
  10. HP Pavilion 15-ab165us Fan Replacement: passo 10, imagem 1 %32 HP Pavilion 15-ab165us Fan Replacement: passo 10, imagem 2 %32 HP Pavilion 15-ab165us Fan Replacement: passo 10, imagem 3 %32
    • Remove the the three 3mm screws with the Phillips#00 screwdriver.
  11. HP Pavilion 15-ab165us Fan Replacement: passo 11, imagem 1 %32 HP Pavilion 15-ab165us Fan Replacement: passo 11, imagem 2 %32
    • Remove the fan from the motherboard.
Conclusão
Chad Christy
Membro desde: 11/07/19
205 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team S3-G1, Harley Fall 2019 Membro de IUPUI, Team S3-G1, Harley Fall 2019
IUPUI-HARLEY-F19S3G1
4 Membros
Autoria de 2 guias
0 Guide Comments
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Ao todo: 640
