Ir para o conteúdo principal
HP Pavilion 15-ab165us Battery and Back Cover Replacement
Dillon Hubble
Dillon Hubble e 8 outros colaboradores
Última atualização em April 8, 2021
10 - 15 minutos
Moderada
Most components that need to be replaced are inside the base of the laptop. The computer will need to be disassembled in order to reach the inner components. You will remove the battery before delving into the innards of your computer. If you just came here for a battery guide, simply follow to step two and then reassemble!
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. HP Pavilion 15-ab165us Battery and Back Cover Replacement, Battery and Back Cover: passo 1, imagem 1 %32 HP Pavilion 15-ab165us Battery and Back Cover Replacement, Battery and Back Cover: passo 1, imagem 2 %32
    • Flip the computer over so that the bottom cover is facing you.
    • Slide the two locks to the "unlock" position and remove the battery.
  2. HP Pavilion 15-ab165us Battery and Back Cover Replacement: passo 2, imagem 1 %32 HP Pavilion 15-ab165us Battery and Back Cover Replacement: passo 2, imagem 2 %32 HP Pavilion 15-ab165us Battery and Back Cover Replacement: passo 2, imagem 3 %32
    • Remove the two 8mm screws underneath with a Phillips #1 screwdriver.
    • Use a plastic opening tool to remove the plastic feet.
  3. HP Pavilion 15-ab165us Battery and Back Cover Replacement: passo 3, imagem 1 %32 HP Pavilion 15-ab165us Battery and Back Cover Replacement: passo 3, imagem 2 %32 HP Pavilion 15-ab165us Battery and Back Cover Replacement: passo 3, imagem 3 %32
    • Remove the two plastic tabs with a metal spudger.
  4. HP Pavilion 15-ab165us Battery and Back Cover Replacement: passo 4, imagem 1 %32
    • Remove the sixteen 8mm screws that hold the bottom cover with a Phillips #1 screwdriver.
  5. HP Pavilion 15-ab165us Battery and Back Cover Replacement: passo 5, imagem 1 %32
    • Pull the Optical Drive out.
  6. HP Pavilion 15-ab165us Battery and Back Cover Replacement: passo 6, imagem 1 %32
    • Remove the 3mm screws that were hidden under the Optical Drive with a Phillips #0 screwdriver.
  7. HP Pavilion 15-ab165us Battery and Back Cover Replacement: passo 7, imagem 1 %32 HP Pavilion 15-ab165us Battery and Back Cover Replacement: passo 7, imagem 2 %32
    • Flip the computer back over.
    • Use a plastic opening tool to release the clips holding the keyboard section in place.
  8. HP Pavilion 15-ab165us Battery and Back Cover Replacement: passo 8, imagem 1 %32
    • Close the lid and pull the screen and keyboard section up and away from the disconnected bottom cover.
    • The hard drive is NOT screwed into place on the underside of the keyboard section.
Conclusão
10 outras pessoas executaram este guia.
Dillon Hubble
Membro desde: 10/20/17
653 Reputação
Autoria de 3 guias
Equipe
UW Tacoma, Team S1-G2, Rose Fall 2017 Membro de UW Tacoma, Team S1-G2, Rose Fall 2017
UWT-ROSE-F17S1G2
Membros da 5
Autoria de 14 guias
Um comentário
Where can i buy the case? I couldn’t anywhere online??
Model - HP Pavilion 15 8th gen B&O
Jackson Beno - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 32
Últimos 30 dias: 65
Duração total: 66,464
