Ir para o conteúdo principal
HP Envy m6-n010dx Fan Replacement
Sandra Ramirez
Sandra Ramirez e 2 outros colaboradores
Última atualização em May 24, 2018
15 - 20 minutos
Moderado
Introdução
Ir para o passo 1
This guide demonstrates how to properly remove the fan of a HP Envy m6-n010dx. You will be using a Phillips 00 screwdriver throughout this guide.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. HP Envy m6-n010dx Fan Replacement, Battery: passo 1, imagem 1 %32 HP Envy m6-n010dx Fan Replacement, Battery: passo 1, imagem 2 %32 HP Envy m6-n010dx Fan Replacement, Battery: passo 1, imagem 3 %32
    • Find the battery removal slider.
    • Slide it across while simultaneously popping out and removing the device's battery.
  2. HP Envy m6-n010dx Fan Replacement, Hard Drive: passo 2, imagem 1 %32
    • Remove the five marked screws found under the battery using a philips head screwdriver.
  3. HP Envy m6-n010dx Fan Replacement: passo 3, imagem 1 %32 HP Envy m6-n010dx Fan Replacement: passo 3, imagem 2 %32
    • Remove the small panel on the back by prying it off. This should reveal the hard drive.
  4. HP Envy m6-n010dx Fan Replacement: passo 4, imagem 1 %32 HP Envy m6-n010dx Fan Replacement: passo 4, imagem 2 %32 HP Envy m6-n010dx Fan Replacement: passo 4, imagem 3 %32
    • The hard drive is connected to the motherboard via this blue-tabbed cable, highlighted in red.
    • Gently pry off the cover to release the cable.
    • Slowly lift the hard drive out and away from the device.
  5. HP Envy m6-n010dx Fan Replacement, Fan: passo 5, imagem 1 %32 HP Envy m6-n010dx Fan Replacement, Fan: passo 5, imagem 2 %32 HP Envy m6-n010dx Fan Replacement, Fan: passo 5, imagem 3 %32
    • Remove the screws highlighted in red
    • Pry off with prying tool the lower two grip pads highlighted in orange
    • You may need to use more force than feels necessary
    • Remove the two additional screws underneath the lower grip pads
    • Remove the large back panel to reveal the inner workings
    • The back panel might be difficult to remove. Use a flat object to help pry it off, and don't be afraid to use force.
  6. HP Envy m6-n010dx Fan Replacement: passo 6, imagem 1 %32 HP Envy m6-n010dx Fan Replacement: passo 6, imagem 2 %32 HP Envy m6-n010dx Fan Replacement: passo 6, imagem 3 %32
    • Locate fan
    • Gently remove tape that hold the heatsink and fan together
    • When reassembling , make sure to use new electrical tape so it will stick.
  7. HP Envy m6-n010dx Fan Replacement: passo 7, imagem 1 %32 HP Envy m6-n010dx Fan Replacement: passo 7, imagem 2 %32 HP Envy m6-n010dx Fan Replacement: passo 7, imagem 3 %32
    • Loosen the four screws on the heat sink indicated in picture
    • Remove the heatsink
  8. HP Envy m6-n010dx Fan Replacement: passo 8, imagem 1 %32 HP Envy m6-n010dx Fan Replacement: passo 8, imagem 2 %32
    • Gently disconnect the wire connecting the fan to the motherboard
  9. HP Envy m6-n010dx Fan Replacement: passo 9, imagem 1 %32 HP Envy m6-n010dx Fan Replacement: passo 9, imagem 2 %32 HP Envy m6-n010dx Fan Replacement: passo 9, imagem 3 %32
    • Remove screws indicated in photo.
    • Remove fan
Conclusão
6 outras pessoas executaram este guia.
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 9
Ao todo: 1,087
