Ir para o conteúdo principal
HP Envy dv7t-7200 Optical Disc Drive Replacement
Krystal
Krystal e 3 outros colaboradores
Última atualização em December 29, 2017
2 - 3 minutos
Moderado
Melhor Introdução
O que você precisa
Ferramentas
  1. HP Envy dv7t-7200 Optical Disc Drive Replacement, Battery: passo 1, imagem 1 %32
    • Turn the power off and disconnect all cables and cords from the laptop.
    • Place the computer on its top on a flat surface with the hinges facing away from you.
  2. HP Envy dv7t-7200 Optical Disc Drive Replacement: passo 2, imagem 1 %32 HP Envy dv7t-7200 Optical Disc Drive Replacement: passo 2, imagem 2 %32 HP Envy dv7t-7200 Optical Disc Drive Replacement: passo 2, imagem 3 %32
    • Slide the battery release latch to the left which is located on the right-hand side of the battery.
  3. HP Envy dv7t-7200 Optical Disc Drive Replacement: passo 3, imagem 1 %32
    • Tilt the battery away from you and lift out.
  4. HP Envy dv7t-7200 Optical Disc Drive Replacement, Service Cover: passo 4, imagem 1 %32
    • Using a Phillips #01 screwdriver, remove the Phillips PM2.5×5.5 screw on the service cover.
    • This screw does not come out of the service cover completely once loosened.
  5. HP Envy dv7t-7200 Optical Disc Drive Replacement: passo 5, imagem 1 %32 HP Envy dv7t-7200 Optical Disc Drive Replacement: passo 5, imagem 2 %32
    • Slide the service cover toward the front of the laptop.
    • Lift the service cover to remove it from the laptop.
  6. HP Envy dv7t-7200 Optical Disc Drive Replacement, Optical Disc Drive: passo 6, imagem 1 %32
    • Remove the Phillips PM2.5×4.0 screw that attaches the optical drive to the laptop.
  7. HP Envy dv7t-7200 Optical Disc Drive Replacement: passo 7, imagem 1 %32 HP Envy dv7t-7200 Optical Disc Drive Replacement: passo 7, imagem 2 %32
    • Press the tab with a metal spudger that is located next to the screw to release the optical drive.
  8. HP Envy dv7t-7200 Optical Disc Drive Replacement: passo 8, imagem 1 %32 HP Envy dv7t-7200 Optical Disc Drive Replacement: passo 8, imagem 2 %32
    • Slide the disk drive out of the laptop.
Conclusão
Uma outra pessoa concluiu este guia.
Krystal
Membro desde: 10/16/17
882 Reputação
Autoria de 8 guias
Equipe
UW Tacoma, Team S3-G3, Liner Fall 2017 Membro de UW Tacoma, Team S3-G3, Liner Fall 2017
UWT-LINER-F17S3G3
5 Membros
Autoria de 8 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 135
