HP Elitebook Folio 9470m WiFi Card Replacement
Introdução
Ir para o passo 1So you are having trouble keeping your EliteBook Folio 9470m connected to Wi-Fi. Look no further, because we have the answer to your problem—you have a malfunctioning WI-FI card! Replacing the card for a new one will resolve the annoying connectivity issue and can even benefit the overall performance of your network—no more unexpected slowdowns, interruptions, and headaches, all with just a quick and simple fix! This guide provides a detailed walk-through on how to replace your Wi-Fi card, ensuring that you stay seamlessly connected from now on.
Before you begin, ensure your laptop is powered off and disconnected from all power sources, including the charger, to avoid electrical hazards. Be sure to handle the Wi-Fi card by its edges and avoid touching the gold connectors to keep it in optimal condition. Follow these precautions and the guide, and you'll be reconnected in no time!
O que você precisa
Ferramentas
4 outras pessoas executaram este guia.
