Ir para o conteúdo principal
HP Elitebook 8570w Keyboard Replacement
Marko Tardio
Marko Tardio e 3 outros colaboradores
Última atualização em October 17, 2024
20 minutos
Moderada
Precisa de melhores imagens
This replacement guide will show you how to disconnect the keyboard from your HP EliteBook 8570w. It consists of 7 moderately difficult steps that should guide you successfully.
O que você precisa
Ferramentas
  • Phillips #0 Screwdriver
  • Spudger
    Spudger
  1. HP Elitebook 8570w Keyboard Replacement, Keyboard: passo 1, imagem 1 %32
    • Begin by removing the back cover of the computer.
    • Push the marked slider to the right.
    • While pushing the slider, pull the cover towards yourself to remove.
  2. HP Elitebook 8570w Keyboard Replacement: passo 2, imagem 1 %32
    • Locate the 3 screws marked in the photo.
    • Using a Phillips screwdriver, unscrew all 3 0.8mm screws completely and place to the side.
  3. HP Elitebook 8570w Keyboard Replacement: passo 3, imagem 1 %32 HP Elitebook 8570w Keyboard Replacement: passo 3, imagem 2 %32
    • Flip the computer so it is laying on its side.
    • Using your fingers or a tool, begin to wedge back/pull off the top of the keyboard panel.
    • Once freeing the keyboard panel from the computer, it should look like photo #2.
  4. HP Elitebook 8570w Keyboard Replacement: passo 4, imagem 1 %32
    • Locate all 3 places of attachment marked in the photo.
    • Each de-attachment is explained in the following steps.
  5. HP Elitebook 8570w Keyboard Replacement: passo 5, imagem 1 %32 HP Elitebook 8570w Keyboard Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Locate the white rectangle base beneath the blue and white strip attached to the computer and keyboard.
    • Using a wedging tool, pull the white base up slightly to loosen the grip on the blue and white strip.
    • With the white base slightly risen, use tweezers to carefully pull out/remove the strip from the computer.
  6. HP Elitebook 8570w Keyboard Replacement: passo 6, imagem 1 %32 HP Elitebook 8570w Keyboard Replacement: passo 6, imagem 2 %32
    • Locate the white rectangle base beneath the burn orange strip attached to the computer and the keyboard.
    • Like the previous step, use a plastic or nylon tool to slightly raise the white base to loosen the grip on the ribbon cable.
    • Using tweezers or your fingers, carefully pull up on the ribbon cable to completely detach it from the computer.
  7. HP Elitebook 8570w Keyboard Replacement: passo 7, imagem 1 %32
    • Locate the black rectangle base at the bottom of the thick ribbon cable.
    • Like previous steps, use a tool to wedge the base upward to slightly lift it in order to loosen the grip on the silver ribbon cable.
    • While the base is lifted, use your fingers to carefully pull out the silver ribbon cable thus freeing it from the computer.
Conclusão
3 outras pessoas executaram este guia.
Marko Tardio
Membro desde: 11/06/17
226 Reputação
Autoria de 1 guia
Equipe
Baylor, Team S8-G5, Johnson Fall 2017 Membro de Baylor, Team S8-G5, Johnson Fall 2017
BU-JOHNSON-F17S8G5
Membros da 3
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 44
Duração total: 7,786
