Ir para o conteúdo principal
HP ElitePad 900 Volume Control Buttons Replacement
Kyle Marques
Kyle Marques e 7 outros colaboradores
Última atualização em January 2, 2024
35 - 45 minutos
Moderada
Fotos de ação
Precisa de mais images
Use this guide to replace the volume control buttons in your HP ElitePad tablet (Model 900). If the buttons on your tablet are not working properly or seem to be getting jammed consistently, they may need to be replaced. The volume buttons control the volume within the device and function by being pressed on from the sides of the tablet. The functionality of these buttons should be able to move back and forth in order to increase or decrease volume. Volume control buttons that are unable to be pressed all the way down or feel loose or have no response when being pressed down need to be replaced. Before using this guide ensure that nothing is in the way of the buttons preventing them from working. Prior to beginning the process of replacing the buttons it is important that the device is fully turned off and disconnected from any external power sources.
O que você precisa
Ferramentas
Exibir mais…
  1. HP ElitePad 900 Volume Control Buttons Replacement, Front Panel Assembly: passo 1, imagem 1 %32
    • Unscrew the two 2.8mm Phillips #000 screws near the power connector.
  2. HP ElitePad 900 Volume Control Buttons Replacement: passo 2, imagem 1 %32 HP ElitePad 900 Volume Control Buttons Replacement: passo 2, imagem 2 %32
    • Use a suction cup to pull the display assembly up.
  3. HP ElitePad 900 Volume Control Buttons Replacement: passo 3, imagem 1 %32 HP ElitePad 900 Volume Control Buttons Replacement: passo 3, imagem 2 %32
    • Use the tip of a spudger to disconnect the two display ZIF connectors.
  4. HP ElitePad 900 Volume Control Buttons Replacement, Volume Control Buttons: passo 4, imagem 1 %32 HP ElitePad 900 Volume Control Buttons Replacement, Volume Control Buttons: passo 4, imagem 2 %32 HP ElitePad 900 Volume Control Buttons Replacement, Volume Control Buttons: passo 4, imagem 3 %32
    • Using the Phillips screwdriver remove the two 2.4mm #000 screws that are securing the volume control buttons to the device.
    • Lift up the silver panel, removing it completely from the device
    • Push the buttons through the slot to remove them from the device
Conclusão
Kyle Marques
Membro desde: 09/03/15
889 Reputação
Autoria de 6 guias
Equipe
USF Tampa, Team 12-4, Blackwell Fall 2015 Membro de USF Tampa, Team 12-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G4
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 6
Duração total: 693
