Ir para o conteúdo principal
HP EliteBook 8560p Hard Drive Replacement
Isaiah Villalobos
Isaiah Villalobos e 2 outros colaboradores
Última atualização em June 19, 2024
15 - 25 minutos
Moderada
Guia do aluno destaque
There are many reasons why you might need to replace a hard drive, including hardware failure, corruption, or insufficient space. These issues can lead to lags, blue screens, file loss, frozen programs, and other symptoms on your device. This guide demonstrates how to replace the hard drive on an HP EliteBook 8560p.
Be aware that when replacing a hard drive, you may or may not need to reinstall your operating system. Before you begin, backup any important documents or files in case of any issues during the repair. Turn off your laptop and unplug it from the charger.
O que você precisa
Ferramentas
Exibir mais…
  1. HP EliteBook 8560p Hard Drive Replacement, Hard Drive: passo 1, imagem 1 %32
    • Before you begin the repair, make sure the laptop is off, unplugged from the power adapter, and the battery is removed.
    • Flip the laptop over so the bottom is facing up.
  2. HP EliteBook 8560p Hard Drive Replacement: passo 2, imagem 1 %32 HP EliteBook 8560p Hard Drive Replacement: passo 2, imagem 2 %32 HP EliteBook 8560p Hard Drive Replacement: passo 2, imagem 3 %32
    • Slide and hold the battery lock all the way to the left.
    • While holding the lock open, slide the battery up and out.
    • If the slot for the battery is dirty, cleaning with a microfiber cloth is recommended.
  3. HP EliteBook 8560p Hard Drive Replacement: passo 3, imagem 1 %32 HP EliteBook 8560p Hard Drive Replacement: passo 3, imagem 2 %32 HP EliteBook 8560p Hard Drive Replacement: passo 3, imagem 3 %32
    • Slide and hold the back cover lock all the way to the right.
    • While holding the lock all the way to the right, slide the back cover down and lift the cover.
  4. HP EliteBook 8560p Hard Drive Replacement: passo 4, imagem 1 %32 HP EliteBook 8560p Hard Drive Replacement: passo 4, imagem 2 %32 HP EliteBook 8560p Hard Drive Replacement: passo 4, imagem 3 %32
    • Carefully slide the hard drive to the left and lift it out.
  5. HP EliteBook 8560p Hard Drive Replacement: passo 5, imagem 1 %32 HP EliteBook 8560p Hard Drive Replacement: passo 5, imagem 2 %32 HP EliteBook 8560p Hard Drive Replacement: passo 5, imagem 3 %32
    • Clean the surface and slide in the new hard drive.
  6. HP EliteBook 8560p Hard Drive Replacement: passo 6, imagem 1 %32 HP EliteBook 8560p Hard Drive Replacement: passo 6, imagem 2 %32 HP EliteBook 8560p Hard Drive Replacement: passo 6, imagem 3 %32
    • Slide the battery back into place.
    • Slide the battery lock to the right to secure the battery.
  7. HP EliteBook 8560p Hard Drive Replacement: passo 7, imagem 1 %32 HP EliteBook 8560p Hard Drive Replacement: passo 7, imagem 2 %32 HP EliteBook 8560p Hard Drive Replacement: passo 7, imagem 3 %32
    • Replace the back cover.
    • While pushing the back cover upwards, slide the back cover lock to the left.
    • Be sure that both locks are properly closed. The red markers should not be seen.
Conclusão
Make sure to keep your available data space at an optimal level to ensure that your device runs at a normal pace.
Isaiah Villalobos
Membro desde: 03/05/24
145 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 26
Duração total: 322
