HP Elite X2 1013 G3 Fingerprint Scanner Replacement
Introdução
Ir para o passo 1If your laptops Fingerprint Scanner is damaged or no longer functioning reliably, use this guide to remove and replace it.
O que você precisa
Flip the device over so the base is facing the ceiling.
Lift up the tablet stand.
Remove the four 2 mm screws from the tablet using a T5 Torx screwdriver.
Use the Phillips #00 screwdriver to remove the six 2 mm screws.
Gently disconnect the two connectors.
