Ir para o conteúdo principal
HP ENVY 5530 Paper Tray Replacement
Elizabeth Surface
Elizabeth Surface e 3 outros colaboradores
Última atualização em April 18, 2023
5 minutos
Fácil
Paper trays help align papers once printed. Over time, the paper tray may lock itself or break. Ensure you have unplugged your device before you begin this repair.
O que você precisa
Ferramentas
  1. HP ENVY 5530 Paper Tray Replacement, Paper Tray: passo 1, imagem 1 %32 HP ENVY 5530 Paper Tray Replacement, Paper Tray: passo 1, imagem 2 %32
    • Grab both sides of the printer and flip it away from you so the bottom is facing up.
  2. HP ENVY 5530 Paper Tray Replacement: passo 2, imagem 1 %32
    • Locate the 13mm TR10 Torx screws on the left side of the paper tray.
  3. HP ENVY 5530 Paper Tray Replacement: passo 3, imagem 1 %32 HP ENVY 5530 Paper Tray Replacement: passo 3, imagem 2 %32
    • Unscrew and remove the 13mm TR10 Torx Security screw, starting with the farthest screw on the left
  4. HP ENVY 5530 Paper Tray Replacement: passo 4, imagem 1 %32 HP ENVY 5530 Paper Tray Replacement: passo 4, imagem 2 %32
    • Locate and remove middle 13mm TR10 Torx Security screw using a Torx screwdriver.
  5. HP ENVY 5530 Paper Tray Replacement: passo 5, imagem 1 %32 HP ENVY 5530 Paper Tray Replacement: passo 5, imagem 2 %32
    • Locate and remove the last 13mm TR10 Torx Security screw.
  6. HP ENVY 5530 Paper Tray Replacement: passo 6, imagem 1 %32 HP ENVY 5530 Paper Tray Replacement: passo 6, imagem 2 %32
    • Locate the side tab and lift up to remove.
  7. HP ENVY 5530 Paper Tray Replacement: passo 7, imagem 1 %32
    • Locate the three 13mm TR10 Torx Security screws on the right side panel.
  8. HP ENVY 5530 Paper Tray Replacement: passo 8, imagem 1 %32 HP ENVY 5530 Paper Tray Replacement: passo 8, imagem 2 %32
    • Locate and remove the farthest 13mm TR10 Torx Security screw.
  9. HP ENVY 5530 Paper Tray Replacement: passo 9, imagem 1 %32 HP ENVY 5530 Paper Tray Replacement: passo 9, imagem 2 %32
    • Locate middle 13mm TR10 Torx Security screw and remove it.
  10. HP ENVY 5530 Paper Tray Replacement: passo 10, imagem 1 %32 HP ENVY 5530 Paper Tray Replacement: passo 10, imagem 2 %32
    • Locate last 13mm TR10 Torx Security screw and remove it.
  11. HP ENVY 5530 Paper Tray Replacement: passo 11, imagem 1 %32 HP ENVY 5530 Paper Tray Replacement: passo 11, imagem 2 %32
    • Locate tab on the right side panel and lift to remove it.
  12. HP ENVY 5530 Paper Tray Replacement: passo 12, imagem 1 %32
    • The back should look like this.
  13. HP ENVY 5530 Paper Tray Replacement: passo 13, imagem 1 %32 HP ENVY 5530 Paper Tray Replacement: passo 13, imagem 2 %32 HP ENVY 5530 Paper Tray Replacement: passo 13, imagem 3 %32
    • Remove paper tray by pulling it out and away from the printer.
    • Be cautious of jumping springs once pulling out the paper tray.
Conclusão
Elizabeth Surface
Membro desde: 08/26/15
1.465 Reputação
Autoria de 9 guias
Equipe
USF Tampa, Team 4-6, Meier Fall 2015 Membro de USF Tampa, Team 4-6, Meier Fall 2015
USFT-MEIER-F15S4G6
Membros da 4
Autoria de 18 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 22
Duração total: 2,503
