Ir para o conteúdo principal
HP Compaq nc8430 LCD Screen Replacement
Corey Nickerson II
Corey Nickerson II e 3 outros colaboradores
Última atualização em May 7, 2024
30 minutos
Moderado
Precisa de melhores imagens
Precisa de mais images
Faltando Passos
Introdução
Ir para o passo 1
This guide will provide information on how to replace the LCD screen if you ever experience black out screen issues.
O que você precisa
Ferramentas
Exibir mais…
A iFixit ganha comissão quando você compra por estes links.
  1. HP Compaq nc8430 LCD Screen Replacement, Battery: passo 1, imagem 1 %32
    • Completely shut down the device and unplug any adapters and cords connected to the device.
    • Carefully flip the device over so that the bottom is facing up.
    • Slide both of the latches to the left.
  2. HP Compaq nc8430 LCD Screen Replacement: passo 2, imagem 1 %32
    • Slide up against the three lines the battery has.
  3. HP Compaq nc8430 LCD Screen Replacement: passo 3, imagem 1 %32
    • Slide the battery up and away from the laptop.
    • Slowly remove the battery to prevent any connectors from getting damaged.
  4. HP Compaq nc8430 LCD Screen Replacement, LCD Screen: passo 4, imagem 1 %32
    • Remove the four 1.2mm Phillip #1 screws circled.
    • The laptop may have rubber covers over the screws,. Remove them using a pointed tool to pry them out.
  5. HP Compaq nc8430 LCD Screen Replacement: passo 5, imagem 1 %32 HP Compaq nc8430 LCD Screen Replacement: passo 5, imagem 2 %32
    • Pry up the plastic screen cover with the pry tool.
    • Once a corner of the plastic screen cover is lifted, slide the pry tool around the entire screen until the screen is completely lifted from the base.
  6. HP Compaq nc8430 LCD Screen Replacement: passo 6, imagem 1 %32
    • Remove the 1.2 Phillips screws circled.
  7. HP Compaq nc8430 LCD Screen Replacement: passo 7, imagem 1 %32
    • Remove the four 1.2mm Phillip screws circled.
  8. HP Compaq nc8430 LCD Screen Replacement: passo 8, imagem 1 %32
    • Gently lift the monitor, from the base of the laptop.
    • The laptop will still be connected to the monitor wires located at the bottom of the screen.
  9. HP Compaq nc8430 LCD Screen Replacement: passo 9, imagem 1 %32 HP Compaq nc8430 LCD Screen Replacement: passo 9, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Locate the video cable wires.
    • Gently remove the video cables from the sensor board with tweezers.
  10. HP Compaq nc8430 LCD Screen Replacement: passo 10, imagem 1 %32
    • All cables should be disconnected from the sensor board. Remove the eight 2mm Phillip screws attaching the bezel to the side of the monitor.
    • Attach the bezel to the new replacement screen.
Conclusão
Corey Nickerson II
Membro desde: 03/20/17
111 Reputação
Autoria de 1 guia
Equipe
1Comentário do guia
Could you please charge it using USB.
Cato Nicolai Lund - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 14
Ao todo: 859
