Ir para o conteúdo principal
HP Compaq Presario V5303NR RAM Stick Replacement
Chris Obesky
Chris Obesky e um outro colaborador
Última atualização em June 5, 2018
8 minutos
Moderado
Introdução
Ir para o passo 1
This guide will walk the reader through the process of locating, removing and replacing the RAM Stick in the Compaq Presario. This process will need to be done if the RAM Stick is damaged or corrupted. Alternatively, this can also be followed to upgrade the RAM, as a way of giving the computer more processing power. For older computers like this one, this is an essential process for keeping it relevant.
O que você precisa
Ferramentas
Exibir mais…
  1. HP Compaq Presario V5303NR RAM Stick Replacement, RAM Stick: passo 1, imagem 1 %32 HP Compaq Presario V5303NR RAM Stick Replacement, RAM Stick: passo 1, imagem 2 %32 HP Compaq Presario V5303NR RAM Stick Replacement, RAM Stick: passo 1, imagem 3 %32
    • Turn laptop bottom-side up.
    • Push the battery latch to the left position to unlock the battery.
    • Lift the battery out of its socket.
    • Failure to unplug the computer and remove the battery can result in electrical discharges on contact with the computer's components. This can damage the computer or even hurt the user.
  2. HP Compaq Presario V5303NR RAM Stick Replacement: passo 2, imagem 1 %32 HP Compaq Presario V5303NR RAM Stick Replacement: passo 2, imagem 2 %32
    • Use the Phillips #0 Screwdriver to remove the 2 5mm screws.
  3. HP Compaq Presario V5303NR RAM Stick Replacement: passo 3, imagem 1 %32
    • Remove the plastic cover panel.
  4. HP Compaq Presario V5303NR RAM Stick Replacement: passo 4, imagem 1 %32 HP Compaq Presario V5303NR RAM Stick Replacement: passo 4, imagem 2 %32
    • Remove the circular, black piece of plastic shown in the picture by pulling it away from the air vent.
    • Use the Phillips #00 screwdriver to loosen, but not remove, the two 4mm screws shown in the picture.
  5. HP Compaq Presario V5303NR RAM Stick Replacement: passo 5, imagem 1 %32
    • Lift open the metal access hatch.
  6. HP Compaq Presario V5303NR RAM Stick Replacement: passo 6, imagem 1 %32 HP Compaq Presario V5303NR RAM Stick Replacement: passo 6, imagem 2 %32
    • Pull the highlighted latches away from the sides of the RAM Stick to unlock it.
  7. HP Compaq Presario V5303NR RAM Stick Replacement: passo 7, imagem 1 %32
    • Pull the RAM Stick toward the metal cover's hinge to unplug the RAM stick.
    • Be gentle when removing or installing the RAM. If it breaks, it could damage the adapter that the RAM plugs into.
  8. HP Compaq Presario V5303NR RAM Stick Replacement: passo 8, imagem 1 %32
    • Carefully remove the unplugged RAM stick through the access hatch.
Conclusão
Chris Obesky
Membro desde: 03/16/18
617 Reputação
Autoria de 3 guias
Equipe
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 329
