HP Compaq C700 Keyboard Replacement
Introdução
Ir para o passo 1In this guide, you will learn how to remove the keyboard of the HP Compaq C700 laptop.
O que você precisa
Ferramentas
Locate and unscrew the two screws on the back marked with a small keyboard. These screws hold the keyboard in place.
Locate the metal hooks where the keyboard connects to the laptop and use a metal spudger to gently pry up the keyboard.
Uma outra pessoa concluiu este guia.
2Comentários do guia
there is a third screw holding in the keyboard located under the RAM cover not mentioned in this guide, please make sure you remove that too or else you may end up warping your keyboard like my friend did with his C700.
