Ir para o conteúdo principal
HP 7 Plus 1302 Power and Volume Button Replacement
Shannon Suttles
Shannon Suttles e 5 outros colaboradores
Última atualização em June 23, 2022
5 minutos
Fácil
Precisa de melhores imagens
Introdução
Ir para o passo 1
If the device buttons are unresponsive then it may be necessary to replace them. The most difficult step will be removing the back cover, it is important to make sure you have all tools required and follow the instructions precisely.
O que você precisa
Ferramentas
Exibir mais…
  1. HP 7 Plus 1302 Power and Volume Button Replacement, Back Cover: passo 1, imagem 1 %32
    • Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
    • Device should be turned off and unplugged before starting the replacements.
  2. HP 7 Plus 1302 Power and Volume Button Replacement: passo 2, imagem 1 %32 HP 7 Plus 1302 Power and Volume Button Replacement: passo 2, imagem 2 %32
    • Use the plastic opening tool to push in between the front and the back of the tablet.
    • Slide the plastic opening tool around all 4 sides of the tablet to separate the back cover.
    • Be careful when you are trying to remove the back as it can damage the screen if you force it too much.
  3. HP 7 Plus 1302 Power and Volume Button Replacement: passo 3, imagem 1 %32 HP 7 Plus 1302 Power and Volume Button Replacement: passo 3, imagem 2 %32
    • Continue sliding the plastic opening tool around the tablet until all 4 sides are separated from each other.
    • Remove the back cover.
  4. HP 7 Plus 1302 Power and Volume Button Replacement, Power and Volume Button: passo 4, imagem 1 %32
    • Locate the power and volume buttons on the right side
  5. HP 7 Plus 1302 Power and Volume Button Replacement: passo 5, imagem 1 %32 HP 7 Plus 1302 Power and Volume Button Replacement: passo 5, imagem 2 %32
    • Pop out the power and volume buttons with your hands
Conclusão
Shannon Suttles
Membro desde: 01/29/17
225 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 1-4, Baechle Spring 2017 Membro de IUPUI, Team 1-4, Baechle Spring 2017
IUPUI-BAECHLE-S17S1G4
4 Membros
Autoria de 8 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Ao todo: 291
