Ir para o conteúdo principal
GoPro Karma Harness Replacement
Max Verspieren
Max Verspieren e 2 outros colaboradores
Última atualização em June 18, 2018
5 - 10 minutos
Fácil
Introdução
Ir para o passo 1
Replacing the harness for the GoPro camera is fairly easy. We will tell you how to remove the stabilizer which holds the harness, how to remove camera from the harness, and how to replace the harness itself.
O que você precisa
Ferramentas
  1. GoPro Karma Harness Replacement, Stabilizer: passo 1, imagem 1 %32 GoPro Karma Harness Replacement, Stabilizer: passo 1, imagem 2 %32 GoPro Karma Harness Replacement, Stabilizer: passo 1, imagem 3 %32
    • Locate stabilizer collar’s unlock and lock symbols. Twist the collar counterclockwise to unlock the stabilizer from GoPro Karma body.
    • Place the GoPro Karma on a stable surface with the legs folded in and the stabilizer facing towards yourself.
  2. GoPro Karma Harness Replacement: passo 2, imagem 1 %32
    • Remove the stabilizer by pulling the entire stabilizer out of the drone body.
  3. GoPro Karma Harness Replacement, Harness: passo 3, imagem 1 %32 GoPro Karma Harness Replacement, Harness: passo 3, imagem 2 %32 GoPro Karma Harness Replacement, Harness: passo 3, imagem 3 %32
    • Place finger on the tab to open the harness and remove the camera.
    • Be sure to pull the camera straight out lest you damage the connectors.
  4. GoPro Karma Harness Replacement: passo 4, imagem 1 %32
    • Using a Hex 2.0mm screwdriver, remove the two 12 mm hex screws closest to the harness.
  5. GoPro Karma Harness Replacement: passo 5, imagem 1 %32 GoPro Karma Harness Replacement: passo 5, imagem 2 %32 GoPro Karma Harness Replacement: passo 5, imagem 3 %32
    • Pull the harness off of the stabilizer.
    • Be sure to pull the harness straight off lest you damage the connector.
Conclusão
Uma outra pessoa concluiu este guia.
Max Verspieren
Membro desde: 04/19/18
97 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team S25-G14, Maness Spring 2018 Membro de Cal Poly, Team S25-G14, Maness Spring 2018
CPSU-MANESS-S18S25G14
4 Membros
Autoria de 6 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 1,267
