Ir para o conteúdo principal
GoPro Hero3+ Silver Edition Camera Lens Replacement
Patrick Cook
Patrick Cook e 5 outros colaboradores
Última atualização em May 31, 2021
15 - 20 minutos
Moderado
Introdução
Ir para o passo 1
You've had a terrible accident and realized that your GoPro has a crack right through the center of the lens! Use our guide to resurrect you GoPro back to life!
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. GoPro Hero3+ Silver Edition Camera Lens Replacement, Battery: passo 1, imagem 1 %32 GoPro Hero3+ Silver Edition Camera Lens Replacement, Battery: passo 1, imagem 2 %32
    • Push the tab on the back of the device left to remove the plate covering the battery.
  2. GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 2, imagem 1 %32
    • Use the strip of tape on the battery to remove the battery from the housing.
  3. GoPro Hero3+ Silver Edition Camera Lens Replacement, Front Panel: passo 3, imagem 1 %32
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
  4. GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 4, imagem 1 %32
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
  5. GoPro Hero3+ Silver Edition Camera Lens Replacement, Image Sensor: passo 5, imagem 1 %32 GoPro Hero3+ Silver Edition Camera Lens Replacement, Image Sensor: passo 5, imagem 2 %32 GoPro Hero3+ Silver Edition Camera Lens Replacement, Image Sensor: passo 5, imagem 3 %32
    • Locate the four 8.1mm PH00 screws on the corners of the GoPro and unscrew them using the phillips screwdriver.
    • Gently remove the motherboard by using a plastic opening tool to pry it out of the housing.
    • Be careful not to damage the ribbon cable connected to the GoPro housing and motherboard.
  6. GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 6, imagem 1 %32 GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 6, imagem 2 %32
    • Remove the ribbon cable by carefully flipping the black clip up with the plastic opening tool and pulling the cable out.
  7. GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 7, imagem 1 %32
    • Remove the four 4mm PH00 screws attaching the image sensor to the motherboard with your screwdriver.
  8. GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 8, imagem 1 %32 GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 8, imagem 2 %32
    • Pry off the last ribbon cable with a plastic opening tool.
    • Remove the image sensor from the motherboard.
  9. GoPro Hero3+ Silver Edition Camera Lens Replacement, microSD/Expansion Port Assembly: passo 9, imagem 1 %32
    • Using your screwdriver, unscrew three 4mm PH00 screws that will free the metal plate.
    • A small plate will become separated when the rightmost screw is removed. Just place it to the side.
  10. GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 10, imagem 1 %32 GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 10, imagem 2 %32
    • Use the plastic opening tool to pry off the referenced ribbon cable from the motherboard.
    • The microSD and Accessory Board is now ready for removal.
  11. GoPro Hero3+ Silver Edition Camera Lens Replacement, Motherboard: passo 11, imagem 1 %32
    • Remove the single 3.2mm PH00 screw with your screwdriver to detach the motherboard from the mid frame.
  12. GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 12, imagem 1 %32 GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 12, imagem 2 %32 GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 12, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Use a plastic opening tool to gently separate the LCD ribbon cable from the motherboard.
    • Gently remove the motherboard from the midframe using tweezers.
    • Remove motherboard by lifting from the edges. This will reduce the chance of damaging components on the motherboard.
  13. GoPro Hero3+ Silver Edition Camera Lens Replacement, Camera Lens: passo 13, imagem 1 %32
    • Use your PH00 screwdriver to remove the last three screws from the mid frame. This will release the lens housing from the mid frame.
  14. GoPro Hero3+ Silver Edition Camera Lens Replacement: passo 14, imagem 1 %32
    • Carefully remove the lens from the font housing.
Conclusão
9 outras pessoas executaram este guia.
Patrick Cook
Membro desde: 10/01/15
699 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 5-8, Maness Fall 2015 Membro de Cal Poly, Team 5-8, Maness Fall 2015
CPSU-MANESS-F15S5G8
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 5
Ao todo: 2,211
