Ir para o conteúdo principal
GoPro Hero+ LCD Battery Replacement
Kyle
Kyle e 8 outros colaboradores
Última atualização em March 20, 2025
5 minutos
Fácil
Introdução
Ir para o passo 1
The battery is connected to the motherboard with a few wires. Be sure to be careful when removing the battery to not damage the motherboard or the battery.
O que você precisa
Peças
Ferramentas
Exibir mais…
  1. GoPro Hero+ LCD Battery Replacement, Back Panel: passo 1, imagem 1 %32 GoPro Hero+ LCD Battery Replacement, Back Panel: passo 1, imagem 2 %32
    • Be sure to power off the GoPro before you start disassembly.
    • Pop up and pull back on the clip to remove the screen cover and expose the back panel with the touchscreen.
    No parts required! What about the microSD/Micro USB assembly!!!! where to buy?!?!
    WPN - Responder
  2. GoPro Hero+ LCD Battery Replacement: passo 2, imagem 1 %32 GoPro Hero+ LCD Battery Replacement: passo 2, imagem 2 %32
    • Use the metal spudger to pry around the perimeter of the panel.
    • Pry the panel upwards by inserting the metal spudger into the corner crease between the panel and camera shell.
  3. GoPro Hero+ LCD Battery Replacement: passo 3, imagem 1 %32 GoPro Hero+ LCD Battery Replacement: passo 3, imagem 2 %32
    • Pry around the panel to ensure it is not attached to the device.
    • Move the panel to the side so you can access the internal components.
    • The panel is still attached to the rest of the device with a ribbon cable, so be sure to not tear or damage the cable.
    а где можно купить вот этот шлейф соединяющий дисплей и плату.???
    Александр «ivkadre» Карпенко - Responder
  4. GoPro Hero+ LCD Battery Replacement, Battery: passo 4, imagem 1 %32
    • Peel back the rear panel ribbon cable that is adhered to the battery until it is completely separated from the battery.
    • Be careful of metal contacts on strip; they can be sharp.
  5. GoPro Hero+ LCD Battery Replacement: passo 5, imagem 1 %32
    Ferramenta utilizada neste passo:
    • Using tweezers, peel off the copper tape on the right side of the battery.
  6. GoPro Hero+ LCD Battery Replacement: passo 6, imagem 1 %32 GoPro Hero+ LCD Battery Replacement: passo 6, imagem 2 %32
    • Place the plastic opening tool at one of the edges of the battery then pry until the battery is removed from the GoPro.
  7. GoPro Hero+ LCD Battery Replacement: passo 7, imagem 1 %32
    • Use a pair of tweezers to disconnect the battery connector from the motherboard.
    • Gently pull the battery off the motherboard. Pulling vertically off the motherboard will give a clean release.
    Lift the battery connector straight up.
    glenn tanner - Responder
    hi what kind battery can replace for hero+?
    sherwin_0011 - Responder
Conclusão
19 outras pessoas executaram este guia.
Kyle
Membro desde: 08/27/15
219 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 2-4, Blackwell Fall 2015 Membro de USF Tampa, Team 2-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S2G4
4 Membros
Autoria de 20 guias
12Comentários do guia
This is a superb guide but where can one buy a replacement battery? I have looked on the web for the one in your photo but can't find a specific one.
I want to buy one of these cameras but would like to know I can replace the battery.
Thanks.
Andrew - Responder
I am also trying to find the replacement battery for a Hero+. Have found a lot of batteries for all other versions of Gopro cams, but not one single one for a Hero+.
I have also sent an email to Gopro to get help. I am not prepared for an answer but I really would like to get hold of a battery.
Does anyone know how to get one?
Please contact me: rhafsrhafs@gmail.com. Rikard from Sweden.
Thanks
Rikard
Rikard Hård -
hi, do you know where i can get the housing for the gopro hero+ lcd. mine is broken and need a new one but can't find it anywhere...........
chris
christianrisan - Responder
not even amazon?
Mary D'Alesandro -
this is awesome thanks a lot! , i dont want to be rude, but the title says battery replacementnt , why isnt anyone preparing a battery and putting it back in?, All everyone is doing is taking th battery out
John misquita - Responder
This is simply a teardown. Sorry for not being very helpful. There might be an update coming soon.
Mary D'Alesandro -
Nope not even on amazon or eBay, been lokking a long time now....
do you know, where to buy the battery???
beuermangabriel - Responder
pavel.novichkov - Responder
Hey, did anyone find out where to get a battery for the GoPro Hero + LCD ???
Not much point in pull the original one out if you can’t find a replacement…
tedkell1968 - Responder
Where can we buy the battery?
Mhenjill Artajo - Responder
Hi friends! I would like some help to find the specified battery GOPRO+ and buy it. How can I get, please? Thanks - marcos.caldana@yahoo.com.br
marcos.caldana - Responder
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 27
Últimos 30 dias: 180
Ao todo: 39,086
