Ir para o conteúdo principal
Ghost Longboard Wheel Replacement
Patricia Roux
Patricia Roux e 2 outros colaboradores
Última atualização em April 1, 2022
10 - 20 minutos
Fácil
Use this guide to replace the damaged, warped, or dented wheels on your Ghost Longboard. This guide requires minimal skill and no prior experience. It is especially useful if your board is not as fast as it used to be, it has become more difficult to turn, or it does not coast for as long as you would like it to. the ghost longboard wheels are easy to replace.
  1. Ghost Longboard Wheel Replacement, Wheel: passo 1, imagem 1 %32
    • Using a 15 mm socket wrench, unscrew the axle nut.
  2. Ghost Longboard Wheel Replacement: passo 2, imagem 1 %32
    • Using your fingers, remove the axle nut from the axle.
  3. Ghost Longboard Wheel Replacement: passo 3, imagem 1 %32
    • Remove the washer from the axle.
  4. Ghost Longboard Wheel Replacement: passo 4, imagem 1 %32
    • Remove the wheel from the axle.
  5. Ghost Longboard Wheel Replacement: passo 5, imagem 1 %32
    • Remove the second washer from the axle.
  6. Ghost Longboard Wheel Replacement: passo 6, imagem 1 %32
    • Slide a new washer onto the axle.
  7. Ghost Longboard Wheel Replacement: passo 7, imagem 1 %32 Ghost Longboard Wheel Replacement: passo 7, imagem 2 %32
    • Place the new wheel on the axle.
    • Be sure to position the flat side of the wheel so it is facing inward.
  8. Ghost Longboard Wheel Replacement: passo 8, imagem 1 %32
    • Place a second washer on the axle exterior to the wheel.
  9. Ghost Longboard Wheel Replacement: passo 9, imagem 1 %32
    • Place an axle nut on the axle.
  10. Ghost Longboard Wheel Replacement: passo 10, imagem 1 %32
    • Using a 15 mm socket wrench, tighten the axle nut.
    • Be sure to tighten the axle nut enough to prevent the wheel from wobbling, but not so tight as to prohibit the wheel from spinning freely.
Conclusão
Repeat these steps on the three remaining wheels.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 386
