Ir para o conteúdo principal
Getting the right iMac G5 (first generation) fan
Anwar Shiekh
Anwar Shiekh e 4 outros colaboradores
Última atualização em July 26, 2024
10 minutos
Muito fácil
Guia colaborativo
Introdução
Ir para o passo 1
I was surprised to find that the top right fan on the G5 iMac (first generation) changed design; one had 36 blades and gave an annoying whine, while the other design has 29 (a prime number) and yields a comforting hum.
  1. Getting the right iMac G5 (first generation) fan, Getting the right iMac G5 (first generation) fan: passo 1, imagem 1 %32 Getting the right iMac G5 (first generation) fan, Getting the right iMac G5 (first generation) fan: passo 1, imagem 2 %32
    • To the left is the desirable design and to the right the one that generates more noise.
    • ifixit carries both designs and was most helpful in ensuring that I got the correct one.
    • Another way to tell the difference is that the bad design is attached with cross head screws, while the good design is attached with torx screws; however the old screws can be used on a new fan.
Conclusão
The better fan turns an almost unusable G5 iMac into one that is much more acceptable.
Anwar Shiekh
Membro desde: 10/25/10
147 Reputação
Autoria de 1 guia
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 2
Ao todo: 1,059
